Go to Post People don't have to "get" it. They just have to know about it. Once they know about it, then they come to it, experience it, talk to it, learn it, then get it. - Taylor [more]
Unread 30-01-2017, 15:13
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
R01 Question: Please save me from welding
While designing our robot I came to some ambiguity in the rules that I would like some opinions on.
Originally Posted by STEAMworks game manual R01.
The ROBOT (excluding BUMPERS) must have a FRAME PERIMETER, contained within the
BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT.
Minor protrusions no greater than ¼ in. (~6.3 mm) such as bolt heads, fastener ends, weld
beads, and rivets are not considered part of the FRAME PERIMETER.
Originally Posted by R01. Blue Box
To determine the FRAME PERIMETER, wrap a piece of string around
the ROBOT (excluding BUMPERS) at the BUMPER ZONE described in
R23 and pull it taut. The string describes this polygon.
Example: A ROBOT’s chassis is shaped like the letter ‘V’, with a large
gap between chassis elements on the front of the ROBOT. When
wrapping a taut string around this chassis, the string extends across the
gap and the resulting FRAME PERIMETER is a triangle with three sides.
Note: to permit a simplified definition of the FRAME PERIMETER and
encourage a tight, robust connection between the BUMPERS and the
FRAME PERIMETER, minor protrusions such as bolt heads, fastener
ends, rivets, etc. are excluded from the determination of the FRAME
PERIMETER.
Our robots super structure flush with the robots frame perimeter on the front and the back, my method of attaching it was going to be to rivet some gusset plates on the inside and the out side of the drive train. Then issue I is the wording of R01. and its blue box.
The gussets I would use would be made from .09" 7075 aluminum sheet metal, be riveted in. Knowing how small rivet heads are I can easily say that it would be under .25". I just do not know how to interpret the part that I made bold. The words "such as" leaves room for interpretation that have left me uneasy, I would like to say that flat gussets are fine and as long as the assembly is under a .25" but I fear that it might not be. For this reason I am preparing to TIG weld the outer seams.
Did I interpret this rule correctly or can you set me straight saving my team for my some what less than decent TIG welding?
If you can't save me, any TIG welding tips for 6061-T6511 aluminum would be great! I need them, although learning I was welding backwards made a world of improvement.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 30-01-2017, 15:15
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: R01 Question: Please save me from welding
the rivet heads are not part of the frame perimeter. the face of the gusset plate is (likely) the frame perimeter.
can you share a sketch or cad of the arrangement?
Unread 30-01-2017, 15:18
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Your best bet is to ask on the Q&A - anything you get on here is going to be opinion that may or may not be correct.
That said, I'll give you my opinion... a plate is not a minor protrusion, and doesn't fall in line with the examples provided. I would love to be overruled by the Q&A on this so I can be more lenient with teams at inspection. This is generally how I've looked at items like this in the past.
Also, the question arises... does it really matter this year? There's no requirement for the size of the frame perimeter, which makes things easier. The bumper will be backed within 1/4". The only real question, then, is if those plates would constitute a "corner" of the frame perimeter for R22 purposes.
Edit: The above question assumes the plates are within the bumper zone.
2016: Lake Superior WFFA
Unread 30-01-2017, 15:19
PayneTrain's Avatar
PayneTrain PayneTrain is offline
please put down the gun
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
R01 this year does not have the same teeth similar rules did in prior years with the introduction of R03 this year. Check to make sure your design can satisfy R03.
Unread 30-01-2017, 15:23
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
If your gusset plates are down in the bumper zone and would be covered by bumpers, then the gusset plates contribute to the shape of your frame perimeter and if suitably covered with a bumper, you'd be fine.
IF your gusset plates are above the bumpers, 1 quick solution would be to simply mount some of the same kind of material directly below your gussets where it WOULD BE behind your bumper (thus reshaping your frame perimeter to include the gusset material) and you should be fine again.
Unread 30-01-2017, 15:24
Munchskull's Avatar
Team Role: CAD
That is the conclusion I came to.
http://i.imgur.com/DombdNs.png?1
There is a gusset plate on the other side BTW.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 30-01-2017, 15:26
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
If it comes down to welding, I'd try and find a local shop/a mentor with TIG experience to do it. Welding aluminum is hard and you can mess up in a lot of ways, so unless you have a lot of experience go the outsource route.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
I'm assuming your issue is that the gusset is exceeding your frame perimeter. If that's the case, the inspector will not let it slide. The gusset would be illegal as it is not included in R01.
When our team runs into this problem, we get around this with L brackets instead of gussets. Gussets attach two flush faces (the ideal method) while brackets connect two angled (usually and hopefully 90 degrees) faces.
2014: FRC 2169 scouting/spirit, FTC 7897 Mechanical
2015: FRC 2169 Mechanical/CAD
2016: FRC 2169 Mechanical/CAD
2017: FRC 2169 Head of Mechanical
Unread 30-01-2017, 15:27
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
R01 may be less important this year (in and of itself), but it is very important with respect to Bumper Rules, and Starting Configuration - Everything must be inside your Bumpers at the start of the match, and the Bumpers must be properly attached to R01 Frame Perimeter.
Unread 30-01-2017, 15:32
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
This, provided that you do not violate any sizing rules.
This would be a trivial job for any welding shop though, so fret not!
Unread 30-01-2017, 15:33
Munchskull's Avatar
Team Role: CAD
What do you mean by teeth?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 30-01-2017, 15:48
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Hi Anthony,
I believe you are interpreting that rule correctly. The gusset would likely be considered part of the frame perimeter, depending on the inspector. However, I think it's important to note that there is no limit to the frame perimeter this year, so this should not cause you any trouble (assuming the gusset is in the bumper zone and the bumpers fit in the sizing box).
-Bryce
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 30-01-2017, 16:02
Munchskull's Avatar
Team Role: CAD
Originally Posted by Bryce2471 View Post
Hi Anthony,
-Bryce
Thanks you all for the feed back and (unofficially) confirming my sneaking suspicion.
Thanks for the suggestion, I am now in the process of contacting one of my old boy scout leaders who owns an auto body shop in the hopes that they might be able to help.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 30-01-2017, 16:10
Chris is me's Avatar
AKA: Pinecone
Before you break out the welder, there's an easy way to solve this problem. Just shim your robot out with some 1/8" thick spacer at the height of the bumpers! Almost any material will work for this since it will be fully supported by the robot frame behind it - plastic, foam, cardboard even. This will make your frame perimeter slightly larger allowing you to use gussets elsewhere.
Unread 30-01-2017, 16:33
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If the gusset plate is in the bumper zone it really doesn't matter if it is frame perimeter or not. Just make sure your bumper gap to frame is less that 1/4". If necessary strategically placed shims can properly define things. If it is outside the bumper zone, it is a little more problematic. I would make the frame in that area a little smaller. One year ws had to shim out our frame perimeter because of a gusset outside the bumper zone.
I would avoid welding 6061 aluminum if at possible unless you have some one really good with the right gear. Welding completely kills the temper and age hardening.
