Go to Post It will really be different for us (ESPECIALLY since our robot drives consistently this year). - Karibou [more]
Unread 30-01-2017, 16:53
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: LabVIEW POV Help?
POVs in LabVIEW have recently been made much simpler. The same way you would get the axes and buttons on a joystick, there should be a third output array on the Joystick Get vi for POVs. The POV you want will be the first (and only) element in the array. If you index the first element of that array, you will end up with a single integer value. IIRC that integer corresponds to the angle that the POV hat is at, with forward being 0* and CW+. Then you can either send that angle value directly to the servo if you have a 360* servo or use some kind of function to map POV inputs to servo angle outputs. Good luck!
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 30-01-2017, 17:19
Chieftainator1's Avatar
Chieftainator1 Chieftainator1 is offline
AKA: Carson Ausra
FRC #5182 (The Chieftainators)
Rookie Year: 2016
Chieftainator1 is an unknown quantity at this point
Can you show us an example by chance? we still are having trouble, after reading your reply, Thanks!
Unread 30-01-2017, 17:42
Ari423's Avatar
FRC #5987 (Galaxia)
My LabVIEW expired and I'm too lazy to put in the new activation code. Attached is a bad MS Paint drawing of what I think it looks like from memory.
2013: Programmer
Unread 30-01-2017, 18:32
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Here, this diagram should be very helpful.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 01-02-2017, 17:14
AKA: Carson Ausra
Rookie Year: 2016
Ok, I've tried this out with no luck, is there something I'm likely missing? I don't know how to copy my code into Chief Delphi to show you.
Unread 01-02-2017, 17:24
Ari423's Avatar
FRC #5987 (Galaxia)
You can either select the code you want and in one of the menus there's an option like "Make PNG from selection" or you can just take a screen grab with any screen grabbing program.
2013: Programmer
Unread 03-02-2017, 15:28
AKA: Carson Ausra
Rookie Year: 2016
Ok, we figured out my problem and got the code to work, although it goes back to the starting position when we let go of the hat switch, any ideas on how to make it stay in the same spot? thanks
Unread 03-02-2017, 16:53
llung llung is offline
FRC #4048
llung is an unknown quantity at this point
How many places in your code do you set the value to the servo?
Presumably you set some value to the servo when the hat switch is depressed. i would look in the code for any other place where that servo is set and see how your code can reach that location (presumably by way of teleop.vi)
Unread 03-02-2017, 19:04
You probably need to incorporate a feedback node to remember the last value set.
Just how you do that depends on what your code looks like.
Unread 04-02-2017, 08:59
Ari423's Avatar
FRC #5987 (Galaxia)
Another option is to put the servo.set command in a conditional statement and then only set it if the POV value is not -1. Then when the POV value is -1 the servo won't get set to a new value and it will keep its last value.
2013: Programmer
