Go to Post I come to Chief Delphi to get away from the mundane, everyday news. It's part of what makes the forum appealing to me. If I want to read world news, I'll go to digg. - Ryan Dognaux [more]
Unread 30-01-2017, 21:49
joecolo1 joecolo1 is offline
FRC #2410
joecolo1 is an unknown quantity at this point
Swerve Modules are not Consistent
Hello,
My team has chosen to do a swerve style drive train. We purchased modules of andymark http://www.andymark.com/product-p/am-3009.htm and we are having some issues with driving the wheel off the CIM motor. Some of them turn as they are intended to but others have issues with the ring and pinion gear arrangement. Some of them are too tight where as there is another module where it is too loose. This results in each wheel turning at different rates which makes the system not as reliable for autonomous. Does anyone have any suggestions for fixing this issue?
Unread 30-01-2017, 21:51
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Re: Swerve Modules are not Consistent
If you have encoders on the rotating module, you can use a PID loop to set it exactly to the position you need.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 30-01-2017, 21:54
FRC #2410
The wheel is very difficult to spin and causes the gears to make a popping sound when spun by the motor. The gears that turn the wheel are too loose and so it can't properly turn the wheel. So I was wondering if there was a way mechanically to adjust the position of the gears on the module.
Unread 30-01-2017, 22:46
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Please contact support@andymark.com to get their feedback on the situation. They are much more adequate about getting your problem fixed.
461 Westside Boiler Invasion
45 Technokats
