#8
Re: Nav-X error - Cant get readings
I did some testing and was able to get the navX-Micro USB-connected along with the Microsoft LifeCAM HD 3000. However, if "USB 2" is selected, communication to the navX-Micro USB doesn't work. Here's what I tested that does work: navX-Micro USB connected to RoboRIO Rectangular USB Port 1, LifeCam in USB Port 2. LabVIEW navX USB selection: USB 1. Works. navX-Micro USB connected to RoboRIO Rectangular USB Port 2, LifeCam in USB Port 1. LabVIEW navX USB selection: USB 1. Works. So I believe the solution is to simply specify USB 1 in the navX-AE LabVIEW Library; the WPI Libraries are apparently intelligently selecting the second USB port if it can't find a USB serial device in USB port 1. In talking w/Thad House who works on the WPI Serial Port code, USB 2 is only valid for use if another USB Serial device is connected to USB 1. Since the Microsoft LifeCAM HD 3000 is not a USB serial device (based upon what is displayed in the RoboRIO Web Dashboard) this means USB 2 should not be used. I'll write up some clarification on this on the navX-MXP/navX-Micro websites. Hope that helps, - scott Last edited by slibert : 30-01-2017 at 23:12. |
