Go to Post So many possibilities so many different meanings and soo many different opinions. LOL but i guess this is what FIRST is all about. - Bcahn836 [more]
Unread 30-01-2017, 23:41
wesleyac's Avatar
wesleyac wesleyac is offline
AKA: Wesley Aptekar-Cassels
FRC #1678 (Citrus Circuits)
wesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to beholdwesleyac is a splendid one to behold
Re: Robot communication issues
Try setting a static IP for the roboRIO. I've seen that help issues like this before.
Also, what Bkeeneykid is good advice. It seems like you're having a driver station issue, and not a connection issue, as you can deploy code.
You could also try QDriverStation - although you won't be able to use it in official competition, and it does have some issues, you can set the IP for it to try to connect to, which can be useful in debugging.
Downgrading the roborio, radio, and DS firmware one at a time could also help isolate where the issue is. I would save that as a last resort though, since it will take a lot of time.
Originally Posted by The programming team
Define "works."
