Go to Post I must caution against using my sense of humor as any sort of litmus test for good taste. - dlavery [more]
Unread 31-01-2017, 08:04
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
Re: Error with joystick controller and driver station
Originally Posted by CocoGuo View Post
lol, but about the joystick number i already try to change it to 0 and 1 it still giving me the same error....much cry
Are they in port 0 and 1 in the SmartDashboard as we? (Inside the driver station go to USB Devices and check the numbers to the left of the joysticks highlighted green).
Unread 31-01-2017, 08:12
YairZiv's Avatar
Rookie Year: 2016
as well*
Unread 31-01-2017, 15:51
CocoGuo CocoGuo is offline
FRC #3345 (Yellow Jacket 3345)
Rookie Year: 2015
CocoGuo is an unknown quantity at this point
Yep, I already try the port 0 and 1 and the joystick is turning green at the driver station whenever i press it
Unread 31-01-2017, 19:40
pblankenbaker pblankenbaker is online now
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
You have a while(true) in your teleopPeriodic() method. You should do that in an IterativeRobot implementation. Try changing:
	@Override
	public void teleopPeriodic() {
		while(true) {
			robotDrive1.arcadeDrive(leftJoystick.getY()*driveBaseSpeed, rightJoystick.getX());
			robotDrive2.arcadeDrive(leftJoystick.getY()*driveBaseSpeed, rightJoystick.getX());
			gearMotor.set(rightJoystick.getY()*gearMotorSpeed);
			if(rightJoystick.getRawButton(4)) {
				fuelGate.set(1.0*fuelGateSpeed);
			} else if(rightJoystick.getRawButton(5)) {
				fuelGate.set(-1*fuelGateSpeed);
			} else {
				fuelGate.set(0);
			if(rightJoystick.getRawButton(6)) {
				scissorLift.set(1.0*scissorLiftSpeed);
			} else if(rightJoystick.getRawButton(7)) {
				scissorLift.set(-1*scissorLiftSpeed);
			} else {
				scissorLift.set(0);
To:
	@Override
// teleopPeriodic() should do something and exit right away (it should not loop forever)
//		while(true) {
			} else {
				fuelGate.set(0);
			} else {
				scissorLift.set(0);
// Removal of while(true) loop
Hope that helps,
Paul
