Re: Can't connect to the robot
It'd be so much easier if you'd tell us what troubleshooting steps you have taken.
What other directions suggested in this thread and others have you followed? - Does last year's radio still work as you said before? - Turn off all firewalls, anti-virus, and third party network management software on your PC. Those all can block communications depending on how they were configured. - Disable all other network connections (Disable not unplug) - You can also try pinging roborio-6026-frc.local, roborio-6026-frc.lan, roborio-6026-frc.frc-robot.local |
We were having very similar problems as described in the first post in this thread. This fixed it:
Hope this works for anyone looking for a solution to this. |
as well as trying the other suggestions on this thread. After your response, we tried a "ping roborio-2723-frc.lan" (did not work, couldn't find IP) "ping roborio-2723-frc.local" (also failed) and "ping roborio-2723-frc.frc-robot.local" (which got a response). There is no firewall running. It seems that the DNS name is getting assigned incorrectly or not at all by the router, but I'm not a networking expert so I've no idea. Hopefully we can try again with the old radio in the next couple of days to compare results more closely. Quote:
Entering the IP address in the driver station in place of the team number seems to work, but, like I said, it's kind of a guess. It usually comes up as 10.27.23.21 but not always. Thanks for the suggestions. |
Since it works, you can type roborio-2723-frc.frc-robot.local into the Driver Station in place of the team number. That should keep you connected.
There does appear to be an oddity in the construction of the roboRIO DNS name on some setups where it throws that extra frc-robot into the mix. It really disrupts Java/C++ downloads which check a variety of addresses to connect, but not that extra frc-robot address. Then you have to add that extra address to the list it checks. Last edited by Mark McLeod : 01-02-2017 at 08:43. |
The "what do we do meanwhile" bottom line appears to be: 1) The DS won't connect. The workaround you gave handles this. 2) Cannot deploy from Eclipse. Direct connection via USB works around this. Back to the old IFI days. |
Can you clarify what the web page says that the device name is? Is it roboRIO-####-frc or does the name shown in the web page end in .frc-robot?
If so, can you remove .frc-robot to get it to work? Greg McKaskle Last edited by Greg McKaskle : 01-02-2017 at 13:42. Reason: rephrase to clarify |
#7
In the cases I've seen the roboRIO has the expected
On the PC connected to run the Driver Station it might or might not include a DNS Suffix Search List: frc-robot.local (from an ipconfig /all). It appears to be somewhat random on any particular PC, i.e., I can have two side-by-side PC's attempting to connect and one will work, but the other fail. After disconnecting/restarting the radio both PCs may work. Depending on if the PC has the search suffix then the Driver Station will connect, but code download still might fail probably from not including the unexpected DNS suffix. I made Kevin aware of the issue. Last edited by Mark McLeod : 01-02-2017 at 14:28. |
#8
The unexpected ".frc-robot" is apparently confusing both the DS and Eclipse deployment.
What I have seen on my system (Windows 10): 1) Somebody, somewhere, is setting the "Connection-specific DNS Suffix" for the wireless adapter to "frc-robot.local" (see "ipconfig /all"). I don't know how this is happening but it looks broken to me. Radio firmware? 2) If you go to Control Panel->Network and Internet->Network and Sharing Center->Change Adapter Settings->(select) Wi-Fi->(tab)Change settings of this connection->(in dialog, select)Internet Protocol Version 4->Properties->Advanced->(tab)DNS, you'll see what appear to be a couple of ways to override the above setting: a) Change "Append primary..." to "Append these..." and put "local" in the list. -or- b) Put "local" into the "DNS suffix for this connection" box. In very limited testing either seems to work for me. I am NOT a Windows expert (and wouldn't admit it if I were). If those who are disagree, trust them not me. Last edited by buchanan : 02-02-2017 at 00:31. |
#9
I had one case where it didn't help, because the PC suffix was wrong, but I didn't try adding frc-robot.local as an ending on that one. Last edited by Mark McLeod : 02-02-2017 at 10:40. |
#10
One more observation to throw into the mix: everything works for over Ethernet. Interestingly, if I ping the roboRIO over Ethernet, it uses an IPv6 address.
Also, further to my post about netsh: for us it works until we switch the wifi to the Internet. Then when we switch back it is all broken again. The only solution we have which seems to work for eclipse and the drive station (and hopefully GRIP) is to set a static IP address on the roboRIO, then add all host name variants to the Windows host file. This makes me very nervous though: What is going to happen when we get to competition? We really need a permanent solution to this soon. |
#11
#12
We're expecting the Sam problem and easy fixes yet?
#13
Unable to ping the Wifi but able to ping with USB cable to RoboRio.
#14
Don't know how to edit previous post sorry. We solved our problem by simply disabling all wifi connections on the PC except the robot and it connected perfectly. It appears the wifi connection to the internet on the PC was the problem.
