Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Unread 31-01-2017, 11:32
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Programming six motor drive in Java (or c++)
We're a Java shop, and we are running 3 motors per side for drive this year (budget and space willing).
In the past, we have used PWM Y cables to make it all look like 4 motors. This year we want to control all 6 motors independently (easier to troubleshoot and find bad connections @ competition).
The Wpilib drive object only supports 4 motors tops. The solution we used was just to poke the Drive object as usual, then immediately interrogate a controller on each side for it's current power and poke that back into the 3rd motor on each side (the motor that is not part of the Drive object).
The other solution we contemplated was doing a Composite motor object; I think strongback has something like that.
Ours is working fine, but I'm curious how other people solved this problem?
