#16
Re: Polycarbonate vs. Aluminum
If you're using a router, aluminum should be chipped at about the same rate as PC because aluminum can be machined at around 2x the SFM at about 1/2x the chipload per tooth. |
#17
Definitely take a look at their After the Game video on their 2012 intake. Stacking up lexan plates will give you strength and flexibility and are incredibly easy to make replacements of if you break them and you can stack up more plates to add strength and rigidity. |
#18
I think the important thing to realize here is that both materials will work and the best material for you depends on availability and your ability to work with the material.
Try not to fall into the trap of choosing a material because it had the most supportive comments on CD. |
#19
It's certainly a material that is for the most part easier to work with. --- I like polycarb intakes. I like them to be a bit stiffer than 1678's 2014 intake (that violent shaking back and forth gives me the heebie jeebies even though it was fine), so I like to use either Vex's 2x1 polycarbonate tubing or McMaster's 1x1 tubing for some structure. It certainly can be strong enough to do the job - a rough rule of thumb is to double the thickness of the equivalent aluminum part. Aluminum can work too, it just likes to stay bent and doesn't absorb impact energy in the same way. |
#20
A lot of people were unnerved by the swaying from them. If asked about it I would grab one and bend it over 45 degrees and let go to demonstrate my confidence in them.
#21
My team (3357) switched out our aluminum shooter deck/intake aluminum for polycarb in the middle of the season because we had a small crack in it. We also did it because we wanted to decrease weight. It worked well and was able to bend without cracking.
Here's a video of us with it: https://m.youtube.com/watch?v=o-mdnlaoFbs |
#22
I don't understand why teams don't take advantage of material properties like that more often. |
#23
We didn't have issues with it, besides being difficult to assemble.
The key was 2 bearings in the VP mount tube (one on each side of the tube), and then a third bearing on the other polycarb arm. This meant that, even as the arms twisted, the C-C for the chain was held constant. But since the polycarb arm is flexy, the intake shaft isn't over-constrained, even with three bearings (as it would be if all three bearings were held constant relative to each other). Hope this makes sense. Best, -Mike |
#24
To play devil's advocate: consider for this year is the potential violations of R03 with a highly compliant mechanism. An intake that can bend over 45° sideways is great for avoiding damage, but may not meet R03 to an inspector's satisfaction.
This is a pretty significant tangent, but it's not worth making a new thread over. What actually happens when you overconstrain a shaft? Does it automatically bind? Is it somewhat more prone to binding? Is the resistance (load) substantially increased? I know not to do it, but I don't know that actual effects of doing it.
#29
Some potential effects: 1) You won't be able to install the shaft. This is an easy problem to spot. You have three bearings, try to slide the shaft in, and no dice. 2) You figure out a way to install the shaft, with a axially mis-aligned set of three bearings (maybe you constrained the bearings to a rigid member AFTER installing the shaft). In this scenario: 2a) The shaft rotates, but with additional load due to the shaft constantly bending/additional radial load on bearing. This inefficiency can sometimes be hard to spot right away, but can suck power from your system 2b) The whole thing seizes up and won't move. I've seen this happen, especially when the torque applied to the shaft is fairly weak (obviously, since the system is more susceptible to inefficiencies). Like Chris said, do it right, and you won't have issues. But people don't always do it right, so it is important to understand where things can go wrong. Best, -Mike |
#30
As to the OP, we generally treat 1/8" and 1/16" polycarbonate as if it's indestructible in terms of impact damage, and it has yet to let us down. I've been tempted to prototype a "sheet metal robot" made from poly instead of aluminum and take it to an off-season competition, just to see how well it would stand up to full gameplay. ...maybe some day. |
