Go to Post It's not hard, it just requires thought. - Matt Leese [more]
Unread 28-01-2017, 16:44
CocoGuo CocoGuo is offline
FRC #3345 (Yellow Jacket 3345)
Rookie Year: 2015
CocoGuo is an unknown quantity at this point
Error with joystick controller and driver station
I am the programmer from team Yellow Jacket 3345, the driver station is giving me error about the joysticks are not plug in,but ti is plug in right and all show green but we all check the program is no error.And we don't know the problems.
https://www.dropbox.com/s/5bczzz5frj...nshot.png?dl=1
package org.usfirst.frc.team3345.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.Talon;
public class Robot extends IterativeRobot {
	final String defaultAuto = "Default";
	final String customAuto = "My Auto";
	String autoSelected;
	SendableChooser<String> chooser = new SendableChooser<>();
	private RobotDrive robotDrive1, robotDrive2;
	private Joystick leftJoystick, rightJoystick;
	private Spark gearMotor;
	private Talon fuelGate, scissorLift;
	private double driveBaseSpeed = 1.0;
	private double scissorLiftSpeed = 1.0;
	private double fuelGateSpeed = 1.0;
	private double gearMotorSpeed = 1.0;
	@Override
	public void robotInit() {
		chooser.addDefault("Default Auto", defaultAuto);
		chooser.addObject("My Auto", customAuto);
		SmartDashboard.putData("Auto choices", chooser);
		//spark and function part
		robotDrive1 = new RobotDrive(1, 2);
		robotDrive2 = new RobotDrive(3, 4);
		fuelGate = new Talon(5);
		scissorLift = new Talon(6);
		gearMotor = new Spark(0);
		leftJoystick = new Joystick(1);
		rightJoystick = new Joystick(2);
	@Override
	public void autonomousInit() {
		autoSelected = chooser.getSelected();
		// autoSelected = SmartDashboard.getString("Auto Selector",
		// defaultAuto);
		System.out.println("Auto selected: " + autoSelected);
	@Override
	public void autonomousPeriodic() {
		switch (autoSelected) {
		case customAuto:
			// Put custom auto code here
			break;
		case defaultAuto:
		default:
			// Put default auto code here
			robotDrive1.arcadeDrive(0.5, 0.0);
			robotDrive2.arcadeDrive(0.5, 0.0);
			gearMotor.set(0.5);
			fuelGate.set(0.5);
			scissorLift.set(0.5);
			break;
	@Override
	public void teleopPeriodic() {
		while(true) {
			robotDrive1.arcadeDrive(leftJoystick.getY()*driveBaseSpeed, rightJoystick.getX());
			robotDrive2.arcadeDrive(leftJoystick.getY()*driveBaseSpeed, rightJoystick.getX());
			gearMotor.set(rightJoystick.getY()*gearMotorSpeed);
			if(rightJoystick.getRawButton(4)) {
				fuelGate.set(1.0*fuelGateSpeed);
			} else if(rightJoystick.getRawButton(5)) {
				fuelGate.set(-1*fuelGateSpeed);
			} else {
				fuelGate.set(0);
			if(rightJoystick.getRawButton(6)) {
				scissorLift.set(1.0*scissorLiftSpeed);
			} else if(rightJoystick.getRawButton(7)) {
				scissorLift.set(-1*scissorLiftSpeed);
			} else {
				scissorLift.set(0);
	@Override
	public void testPeriodic() {
Unread 28-01-2017, 16:50
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Error with joystick controller and driver station
Joysticks are indexed starting at 0. Change your Joystick numbers from 1 & 2 to 0 & 1.
Unread 29-01-2017, 23:24
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Just curious, why do you have TWO RobotDrive objects? RobotDrive does support 4-motor drive. There is no reason to have two RobotDrive objects.
Unread 30-01-2017, 07:17
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
	@Override
	@Override
		// defaultAuto);
	@Override
		case customAuto:
			break;
		case defaultAuto:
		default:
			gearMotor.set(0.5);
			fuelGate.set(0.5);
			break;
	@Override
		while(true) {
			} else {
				fuelGate.set(0);
			} else {
				scissorLift.set(0);
	@Override
The joystick are counted from 0, if you look in the SmartDashboard in the USB devices sub-folder, you see that near each joystick there's a number, that is the number in the constructor for Joystick. So if you plugged 2 joysticks, and they were in the first 2 positions, but in the constructor you put 1 and 2, it will not find a device in port 2, that will give you an error.
Sorry for the long comment, here's a potato (head).
(`-._____.-')
.. `-._____.-' ..
: ( : ___ ___ : ) ;
'._.: |0| |0| :._.'
/ `-'_`-' \
_.| / \ |._
|| '-._ _.-' ||
/ \ _/ `~:~` \_ / \
\||| (`.___.')-(`.___.') |||/
(Might come out a little mashed)
Unread 30-01-2017, 07:18
YairZiv's Avatar
Rookie Year: 2016
NVM It came out awful, excuse my failure
Unread 30-01-2017, 17:11
Rookie Year: 2015
lol, but about the joystick number i already try to change it to 0 and 1 it still giving me the same error....much cry
Unread 31-01-2017, 08:04
YairZiv's Avatar
Rookie Year: 2016
Are they in port 0 and 1 in the SmartDashboard as we? (Inside the driver station go to USB Devices and check the numbers to the left of the joysticks highlighted green).
Unread 31-01-2017, 08:12
YairZiv's Avatar
Rookie Year: 2016
as well*
Unread 31-01-2017, 15:51
Rookie Year: 2015
Yep, I already try the port 0 and 1 and the joystick is turning green at the driver station whenever i press it
Unread 31-01-2017, 19:40
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
You have a while(true) in your teleopPeriodic() method. You should do that in an IterativeRobot implementation. Try changing:
	@Override
		while(true) {
			} else {
				fuelGate.set(0);
			} else {
				scissorLift.set(0);
To:
	@Override
// teleopPeriodic() should do something and exit right away (it should not loop forever)
//		while(true) {
			} else {
				fuelGate.set(0);
			} else {
				scissorLift.set(0);
// Removal of while(true) loop
Hope that helps,
Paul
