Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
Unread 31-01-2017, 16:08
CjDace's Avatar
CjDace CjDace is offline
Skyline Samurai
AKA: Scotbot Programmers
FRC #4284 (Scotbot)
CjDace is an unknown quantity at this point
Question Axis Camera Sample Error
I'm trying to run the Axis camera sample with a configured M1013. When I deploy the code, the build fails and I get the following message:
BUILD FAILED
C:\Users\ScotBot4284\wpilib\java\current\ant\build .xml:135: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre1.8.0_121"
I've tried uninstalling the JDK and reinstalling it in the default path, but I got the same output. What can I do to get it running? Thanks!
Scotbot Programmers
"I have not failed. I have just found 10,000 ways that do not work."
~ Thomas Edison
Unread 31-01-2017, 16:20
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Axis Camera Sample Error
Your JAVA_HOME environment variable is incorrect. It's pointing at a JRE, not a JDK
Read this for instructions
WPILib
GRIP, RobotBuilder
Unread 02-02-2017, 01:24
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
http://wpilib.screenstepslive.com/s/...eclipse-c-java
Follow the Setting up the JDK in eclipse part.
