Go to Post Off time, at a regional? What is that? - DonRotolo [more]
Unread 27-01-2017, 18:58
matlac7 matlac7 is offline
FRC #4638
matlac7 is an unknown quantity at this point
Connecting and Using a Rotary Optical Encoder with a roboRIO
I have been attempting to use a SRX magnetic encoder and I have had little success. Now, I am going to use this rotary optical encoder:
http://www.allelectronics.com/item/e...encoder/1.html
Specs sheet: http://www.allelectronics.com/mas_as...ec/ENC-128.pdf
How would I connect this to the RIO, and how would I go about using this with Labview?
Thank you for the help!
Unread 31-01-2017, 14:41
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Connecting and Using a Rotary Optical Encoder with a roboRIO
Originally Posted by matlac7 View Post
I have been attempting to use a SRX magnetic encoder and I have had little success...
Did you contact CTRE support? What was wrong with the CTRE Mag encoder?
Unread 31-01-2017, 19:07
FRC #4638
I found the issue, there were file conflicts with the project we were testing with and after fixing that problem the magnetic encoders worked very well. Our team will most likely use the magnetic encoder, thanks!
