Go to Post The phrase "Gracious Professionalism" is being thrown around much too often to try to support anything and everything that a certain individual feels is unjust. - Neo3One3 [more]
Unread 31-01-2017, 13:39
sgk525 sgk525 is offline
FRC #5465
sgk525 is an unknown quantity at this point
Clarity on Smart Dashboard Camera Mechanism
I have developed a straight forward vision code on the Raspberry Pi that grabs a frame, applies masking/Canny Edge Detection, and contour fitting that will send a udp string of distance measurements to the roborio. The main issue I am having is sending an image from the pi to the SmartDashboard. I have been reading about mjpeg streaming, and touched on the mjpeg streamer by robotpy, although am a little confused on how the smartdashboard will grab the frames. I tweaked a stream i found on-line for python3, found here:
https://github.com/SachinKonan/Windo.../httpserver.py
I was wondering how it could be changed to interface with the Smart Dashboard.
Unread 31-01-2017, 16:19
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: Clarity on Smart Dashboard Camera Mechanism
That code as-is should work fine with SmartDashboard, as it appears to be serving up just a standard MJPEG over HTTP stream. For competition you'll want to change the port number from 9090 to one of the ones allowed through the field radio. You'll need to use the mjpg streamer widget rather than the CameraServer widget, and put in the URL manually (e.g. http://10.x.y.z:9090/stream.mjpg), as the CameraServer widget uses information from NetworkTables to find the camera stream URL, and that won't be present in this instance (unless you put it there).
Note this code is inefficient in that it's decompressing and recompressing the image from the camera. The Raspberry Pi likely has enough horsepower to do this, particularly at lower resolutions, but I wanted to note this fact because you'll see more CPU use of this approach versus others for this reason.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 31-01-2017, 18:16
FRC #5465
Thanks, so what will basically happen is I will start an MPEG server on my raspberry pi that is updating frames and sending to the the url you specified, the roborio's background CameraServer class will grab these frames according to the url (http://10.x.y.z:9090/stream.mjpg), and will then send the images to the smartdashboard on the computer?
Also, what might be a faster way of uploading these frames to byte format, because even on my desktop, I am noticing significant lag.
Unread 31-01-2017, 18:27
Hjelstrom's Avatar
Hjelstrom Hjelstrom is offline
FRC #0987 (High Rollers)
Hjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond repute
Its pretty useful to edit the images before you send them. You can draw the OpenCV contours on them, put data on them, etc.
Unread 31-01-2017, 18:49
WPILib Developer
No, the SmartDashboard will connect directly to the Raspberry Pi, bypassing the roboRio entirely.
OpenCV does not provide a way to avoid the decompress+recompress. If you aren't actually editing the images being sent to the dashboard, you can use the cscore library that we use on the roboRio to both send the original camera JPEG via HTTP in the lowest overhead way possible and make it available for OpenCV processing. There's a Java tutorial for this here: http://wpilib.screenstepslive.com/s/...essing-in-java. The RobotPy folks are working on a cscore wrapper that should make this possible to do in Python, but there's not an existing tutorial that I know of.
Unread 31-01-2017, 19:11
FRC #5465
I think I understand now. So I will replace line 34 of my server code with:
self.wfile.write('<img src="http://10.x.y.z:9090/stream.mjpg" height="240px" width="320px"/>')
and thread the server_serve_forever() statement, so that the pi can simultaneously process and set the images in a global variable, perhaps a queue.
So just for clarification, there isn't much I will have to do on my end other than set up a mjpeg stream with an appropriate send port and ip address. The smart dashboard will do the rest by finding the url and grabbing the images.
Unread 31-01-2017, 19:27
WPILib Developer
To be clear, while the format of the URL is what's in the src= portion above, SmartDashboard doesn't use or hit that line of code at all. SmartDashboard will try to connect to whatever URL you configure in its settings. The important line in your code is line 49, which sets up the HTTP server on a particular port.
Unread 31-01-2017, 21:53
FRC #5465
So I have been looking at the smartdashboard camera viewer properties and it asks for the "camera's ip address or mdns name". Here I can feed the URL: "http://10.x.y.z:9090/stream.mjpg" and should it successfully make a connection to the Dash? Should the x, y, and z have integer values? Is it possible to set a mdns name for the http web server?
Also the the ports that are allowed for team use ranges from "5800-5810"
Unread 01-02-2017, 00:40
Have you updated to the 2017 plugins? It sounds like you have an old smartdashboard.
Unread 01-02-2017, 03:21
WPILib Developer
I would not recommend using mDNS with coprocessors. Go with fixed IPs in the 10.team.number.xx range. Yes, for IP addresses, x, y, and z are integers in the range 0-255, but for use on the field, x and y should be derived from the team number (e.g. x=2, y=94 for team 294), and z should not be 0, 255, or 1-5.
The ports allowed for team use are listed in R56. Ports 5800-5810 are one option; another is port 80.
