Go to Post Car Nack called. He said get off his lawn. - Taylor [more]
Unread 31-01-2017, 22:53
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Java external libraries
Can we keep on importing libraries into the build process from custom directories in the same way as before? I used to write the following lines in build.properties file in the project source:
lib.dir=${src.dir}/../lib
userLibs=\
	${lib.dir}/library_1.jar:\
	${lib.dir}/library_2.jar:\
Does this still work considering that the build process now includes files in the wpilib directory?
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 31-01-2017, 23:49
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Java external libraries
Follow the steps in this article to add a library:
http://wpilib.screenstepslive.com/s/...arty-libraries
Unread 01-02-2017, 00:19
AKA: Lucas Alvarez
So I have to add the libraries to \wpilib\user\java\lib? Is this the only way to get the libraries recognized by the build? The thing is that I'd like to include the libraries in the project folder for easier distribution.
I noticed that the build.properties file in wpilib defines the user libraries with
userLibs.dir=${user.home}/wpilib/user/java/lib
I tried overwriting that setting with the following two lines at the end of the build.properties file in my project:
userLibs.dir=${lib.dir}/yamlbeans-1.11.jar:${lib.dir}/commons-collections4-4.1.jar
However, I get the following error message upon deploying:
BUILD FAILED
C:\Users\Lucas\wpilib\java\current\ant\build.xml:124: D:\Lucas\Desktop\FRC\2017\eclipse_workspace\Pie-API\lib\lib\commons-collections4-4.1.jar does not exist.
That's cause I have my libraries in Pie-API/lib/ not Pie-API/lib/lib/. If I remove the /lib from the lib.dir definition, the build process tries to find the libraries in Pie-API/.
I know that I can just place my libraries in a Pie-API/lib/lib/ folder, but I'm sure that I'm doing something awfully wrong. Is there any way of correctly setting a different userLibs.dir directory?
Unread 01-02-2017, 00:40
AKA: Lucas Alvarez
Ok, I got it. I just had to set the userLibs.dir option in my build.properties like:
userLibs.dir=lib
That actually should've been really obvious from the beginning
