Go to Post Honestly, I can't understand why anyone wouldn't want to be a mentor. The fools don't know what they are missing. - Steven Smith [more]
Unread 30-01-2017, 19:21
bacarpenter bacarpenter is offline
Lead programmer (2 years)
AKA: Baylee Carpenter
FRC #2197 (Las Pumas)
bacarpenter is an unknown quantity at this point
Question Peg targeting
I've been trying to use a camera to target the reflective tape around the peg. I've looked at tutorials and examples but I can't get it to recognize the peg tape.
Unread 31-01-2017, 07:53
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Peg targeting
Try adjusting the exposure time and ISO level of the camera or adjusting threshold levels in your processing. Besides that, we can't help you very much without knowing what your code or GRIP pipeline and your sample images look like.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 31-01-2017, 08:18
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Peg targeting
This was posted in the LabVIEW subforum, so I would assume they are using NI Vision instead of GRIP. The point still stands that it's hard for us to help without decent pictures of your code, sample pictures, threshold values, and output post-processing images.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 01-02-2017, 01:34
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Re: Peg targeting
Whoops, didn't notice that the forum section was LabVIEW
Unread 01-02-2017, 09:12
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: Peg targeting
Make sure Enable Vision in Robot Main is true by default.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 08-02-2017, 18:26
Re: Peg targeting
Okay so I've been working on getting my program to detect the high goal target then move the robot to line up with it. I got it to recognize the goal with a lot of help from the FRC vision example. But now I've got two major problems, my vision processing takes forever to process, whenever I move the robot it takes 3 seconds or so for the values to change and this makes it hard to move the robot accurately. Another problem I have is that I have no idea how to get my program to recognize the peg target. I've attached my vision processing code to this post any help on something I could do to make it work faster and/or work with the peg would help a ton.
Name:	Vision Processing.jpg
Unread 08-02-2017, 22:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Peg targeting
At a high level (as my team uses Java rather than LabView):
Vision processing is usually low-rate, high-latency. Use the results of vision processing to drive action based on encoders or an inertial system (gyros and encoder), which return data on much shorter time scales.
Unread 09-02-2017, 02:20
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Peg targeting
Where is this code located? On the dashboard? On the Robot? Or is this just the vision example? What resolution are you running? What compression are you using?
Unread 09-02-2017, 09:11
FRC #3007
Rookie Year: 2015
Re: Peg targeting
This. it's impossible to stress this enough.
Team 3007: 2017
Unread 09-02-2017, 14:20
Re: Peg targeting
Currently my code is located on the roborio and the resolution is set to 360x240 the compression is whatever the default value is I've never changed it. I'm currently working on processing the image on the dashboard instead but I haven't tested it yet. I kinda get what you guys are saying about using another sensor to actually line it up but I don't know exactly how to implement that.
Unread 09-02-2017, 14:31
FRC #3007
Rookie Year: 2015
Re: Peg targeting
Get a cheap gyro, perhaps the ADXRS450, and set it up so that the angle resets every time the vision info changes (in Periodic Tasks.vi in a 10ms loop). That way, you have an angle that, when subtracted from the angle you calculate from your vision data, gives you how far off you are, even when vision doesn't update. At least that's how I did it.
Team 3007: 2017
Unread 09-02-2017, 14:45
Re: Peg targeting
Okay thank you for all your help. I have a gyro currently working on the robot, but the problem I see with using the gyro angle to line it up is distance. Right now my vision code won't figure the distance from the target it just says infinite. If I'm closer or further away that'd change the angle calculations, but right now I don't know how to get that distance.
Unread 09-02-2017, 19:38
FRC #3007
Rookie Year: 2015
https://www.chiefdelphi.com/forums/s...d.php?t=154930 try the code posted in this thread. It's my LabView code that my team won't be using.
Team 3007: 2017
Unread 09-02-2017, 20:23
Re: Peg targeting
okay thank you for that link it helped me a ton. My code know detects the peg target and has a distance that's pretty accurate. Thanks for all your help!
Unread Yesterday, 17:08
Tom Line's Avatar
Re: Peg targeting
This just occurred to me. If you are a LabVIEW team that wants to target the peg, but is struggling to modify the example code to do it:
Try turning your camera on it's side.
You may get a pleasant surprise.
(YMMV, I haven't tried this myself).
