Go to Post Nominate your mentor for WFA, it's the best way to say 'Thank You'. - Brandon Martus [more]
Unread 01-02-2017, 02:28
GavinL GavinL is offline
intensely stares at program
FRC #5726 (RhumBotz)
Rookie Year: 2016
GavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to behold
Question Raspberry Pi 3 Wiring and Programming for Vision
To wire the raspberry pi 3, we use a micro usb that is plugged into the VRM 5v/2a right? And an ethernet cord into the left radio port (the one closest to the power plug)?
After all of that is wired, then what? What do I need to install? Also I'm using C++, or at least I want to.
Unread 01-02-2017, 03:51
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: Raspberry Pi 3 Wiring and Programming for Vision
The port on the radio that is nearest to power, is for directly connecting to the roboRIO. The far port is for connecting *something else* (Pi, Kangaroo, switch, radio kiosk when programming the competition key).
Nate
Unread 01-02-2017, 06:58
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge will become famous soon enough
You can also power the Pi via regular USB-to-micro-USB cable, plugging the USB end into the roboRIO.
Unread 01-02-2017, 07:40
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Get an OS on an SD Card for the PI (Noobs or Raspbian)
https://www.raspberrypi.org/downloads/noobs/
https://www.raspberrypi.org/downloads/raspbian/
Load GRIP onto the Pi
https://github.com/WPIRoboticsProjec...Raspberry-Pi-2
Figure out how to program the pi.
Plug the USB camera into the pi
Unread 01-02-2017, 08:43
Back after 4 years off
FRC #5279
Originally Posted by rich2202 View Post
I don't think that is the recommended method. From the link:
At this time (13 Dec 2016), these instructions do not result in functional code. Multiple issues are open on the topic. According to @bradmiller running GRIP on the Pi or the RoboRio is not recommended. Instead, teams are encouraged to generate a Pipeline class from GRIP and incorporate that into their robot code.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 01-02-2017, 09:15
Rookie Year: 2016
So I generate a pipeline class? How would I use the pi then?
Unread 01-02-2017, 09:46
Rookie Year: 2016
Wish I knew that before, we cut and stripped our friends charger lol.
(We said we are going to get him another one).
But yeah some researching told me to cut and strip a micro usb
Unread 01-02-2017, 10:16
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I'd hate to see what you do to the chargers of people who aren't your friends.
Unread 01-02-2017, 12:02
vScourge's Avatar
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
Install Python and pynetworktables on the Pi. Then write a little helper script that starts on boot, imports your pipeline class from GRIP, calls "process" on it, then feeds the desired values into NetworkTables, making them available to the robot code on the roboRIO.
Unread 01-02-2017, 16:13
Rookie Year: 2016
okay and GRIP is on the DS Laptop or Pi?
p.s. sorry for so many questions
Unread 01-02-2017, 16:34
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
You run GRIP to create a pipeline to find what you're looking for, then generate code to put in the program you run on the pi.
WPILib
GRIP, RobotBuilder
