Go to Post You really don't want to mess with an engineer. - ChrisH [more]
Unread 01-02-2017, 08:10
crc540 crc540 is offline
FRC #3976
crc540 is an unknown quantity at this point
Setting motor speed
How do you set a reduced power/speed to a motor or do you set a variable to the joystick.
Unread 01-02-2017, 08:32
Re: Setting motor speed
If it's based on a joystick axis, then just multiply the axis output by the percentage maximum power you want before you send it to the motor, e.g., (axis 1 * .7 = 70% power)
Unread 01-02-2017, 08:57
FRC #3976
Mark how can I do that. Thank you for your help
Unread 01-02-2017, 09:00
Here's an example: http://www.team358.org/files/program...ickMaxThrottle
The right half is a simple throttle limit.
Unread 01-02-2017, 09:04
FRC #3976
Thanks Mark
