Go to Post You don't just click and drag the "Swerve drive go roundy roundy" VIs from the palette onto the canvas? - marshall [more]
Unread 01-02-2017, 09:15
GavinL GavinL is offline
intensely stares at program
FRC #5726 (RhumBotz)
Rookie Year: 2016
GavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to behold
Re: Raspberry Pi 3 Wiring and Programming for Vision
Originally Posted by JamesBrown View Post
I don't think that is the recommended method. From the link:
So I generate a pipeline class? How would I use the pi then?
Unread 01-02-2017, 12:02
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge will become famous soon enough
Install Python and pynetworktables on the Pi. Then write a little helper script that starts on boot, imports your pipeline class from GRIP, calls "process" on it, then feeds the desired values into NetworkTables, making them available to the robot code on the roboRIO.
Unread 01-02-2017, 16:13
Rookie Year: 2016
okay and GRIP is on the DS Laptop or Pi?
p.s. sorry for so many questions
Unread 01-02-2017, 16:34
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
You run GRIP to create a pipeline to find what you're looking for, then generate code to put in the program you run on the pi.
WPILib
GRIP, RobotBuilder
