Go to Post We don't build robots because it's easy, we do it because it's hard. Maybe we can work on giving new members a warmer and gentler welcome, because it's hard ;). - Winged Globe [more]
Unread 01-02-2017, 14:13
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
pic: Spectrum 3847 - 2017 CAD Model: Gamma Ray
Unread 01-02-2017, 14:14
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: pic: Spectrum 3847 - 2017 CAD Model: Gamma Ray
That arm on the front stays inside the maximum robot volume, right? It looks like you're going with the tall dimension set, and it also looks like lowering that arm is against the rules.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 01-02-2017, 14:19
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
That looks like the short dimension set to me.
Unread 01-02-2017, 14:22
lukekaiser lukekaiser is offline
FRC #5547 (the talons)
Rookie Year: 2016
lukekaiser is an unknown quantity at this point
Agreed
Teams need to make sure they read all rules pertaining to robot size carefully. I would hate to see a robot this well designed get to a competition and then not pass inspection.
Unread 01-02-2017, 14:23
Chris is me's Avatar
AKA: Pinecone
I'm sure they know what they're doing and have read the rules - they're a long standing veteran team who's built high-quality robots for years, who publicly posted a full cad of their robot in week 4.
You don't think it's more likely that you have an inaccurate perception of the robot's dimensions?
It's not against the rules to lower the arm as long as the robot still fits within the volume with the arm lowered (i.e. their chassis is shorter to compensate). This is clearly the case here. If the arm doesn't go past the bumpers then it's legal for it to be lowered even at max dimensions.
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
It's Spectrum, I'm sure they're in the volume. These guys do their due diligence. You can lower an arm outside of your bumpers as long as it all stays within the appropriate robot volume.
Looking slick Allen!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 01-02-2017, 14:28
fresh_prince fresh_prince is offline
Not allowed to navigate or DJ
AKA: Will Smith
Team Role: Student
fresh_prince is an unknown quantity at this point
notmattlythgoe is correct, we are using the short configuration. We are 29x29 so we have room for a 4" extension off either side. The gear collector also fits within our bumper cutout.
See these photos for reference. The pic with the grey gear is current, the pic with the yellow gear is from an older revision, but demonstrates how the intake fits inside our front cutout.
AMDG, LTF
3847 - Spectrum | 2014-2017 | Student
Unread 01-02-2017, 14:31
Engineering Coach
The robot frame is a ~29in square making our dimensions with bumpers about 36" square. That gives us 4 inchs of room to extend past the bumpers. The mecanum intake and the gear intake both come close to the full extension limit but can't possibly break it.
And of course we are short. Top of the robot is 23.8in I believe but the student that's doing most of the shooter CAD can tell you for sure that we are under.
Unread 01-02-2017, 14:34
AKA: Will Smith
Team Role: Student
By my best memory we are ~23.97. I will update this post later in the evening if I'm way off.
AMDG, LTF
Unread 01-02-2017, 14:38
Engineering Coach
Unread 01-02-2017, 14:42
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Allen,
Really cool bot, love what your team is doing with the open build/blog. Seems like a great learning experience for your team.
Whats the process for scoring the gear once in the gear holder?
Great work as always,
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Rookie Year: 2016
Very nice. What is the upper appendage intended for?
Unread 01-02-2017, 14:45
Flywheel Police
Originally Posted by Michael Corsetto View Post
Allen,
-Mike
They talk about some really good details of the gear intake here in the video.
Unread 01-02-2017, 14:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This makes me wonder how they'll inspect boundaries this year. Our arm is 1" within the boundary with fully-down, but comes to within 0.25" of the boundary during articulation up/down.
2017 Scoring Model
CAD Library | GitHub
Unread 01-02-2017, 14:48
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Originally Posted by JesseK View Post
This makes me wonder how they'll test things this year. Our arm is 1" within the boundary with fully-down, but comes to within 0.25" of the boundary during articulation up/down.
In previous years where they had appendage requirements they made the teams extend out to their furthest point and then measured them.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
