Re: PSA: Enable Vision Race Condition
I found that the enable vision variable in Global Data.vi (or something like that) is false unless you press the button and save it as true.
You can still write code that manipulates the variable, causing it to change.
Or replace any instance of the "Enable Vision" variable with a true Boolean.
If you do that while using the variable to simultaneously enable vision code and turn on a ring light, the ring light will be always on, which is not allowed.
Wouldn't it make more sense to create a variable to control your ring light rather than alter the way it's already functioning to control the vision system as a whole?
Per which rule? I'm not seeing it.
#7
R07-M.
It seems clumsy to leave your vision code, which uses a lot of resources, running when it's not in use. Just my opinion, so I followed it. |
#8
R07-M really depends on which light source you're using. If you're using something with a 300 lumen output, you're probably going to have a bad time, but if you're simply just using the LED ring in FC or a smaller LED that was mentioned in another thread, I doubt anyone will rule that illegal. Please note: I am not an inspector. Please at least run it though a spike just in case. The ability to be able to turn it off will not be a bad choice at all. |
#9
I'd imagine you're planning on your team operating in the portions of the field clouded by one, or both, airships. Is your vision code not streaming a feed to your drivers to help them drive the robot in these cases?
#10
The streaming code is a self-looping VI that starts when Vision Processing.vi initializes. It is separate from the actual vision loop that you write. It lies far outside the Enable Vision case structure.
