Go to Post Dear GDC, You are awesome. From, the Chief Delphi folks. - bam-bam [more]
Unread 01-02-2017, 14:41
Hess1113's Avatar
Hess1113 Hess1113 is offline
Grab a computer and code it up!
AKA: Christopher Hess
FRC #0291 (Creativity In Action)
Rookie Year: 2017
Hess1113 is an unknown quantity at this point
Re: PSA: Enable Vision Race Condition
Originally Posted by flemdogmillion View Post
You can still write code that manipulates the variable, causing it to change.
Or replace any instance of the "Enable Vision" variable with a true Boolean.
Christopher Hess
Co-Lead Programmer
Webmaster
FRC-Team 291 CIA
www.team291.com
Unread 01-02-2017, 14:46
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
If you do that while using the variable to simultaneously enable vision code and turn on a ring light, the ring light will be always on, which is not allowed.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 01-02-2017, 17:27
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
Wouldn't it make more sense to create a variable to control your ring light rather than alter the way it's already functioning to control the vision system as a whole?
Unread 01-02-2017, 17:37
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
Per which rule? I'm not seeing it.
Unread 02-02-2017, 09:52
FRC #3007
Rookie Year: 2015
R07-M.
It seems clumsy to leave your vision code, which uses a lot of resources, running when it's not in use. Just my opinion, so I followed it.
Team 3007: 2017
Unread 02-02-2017, 10:03
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
R07-M.
R07-M really depends on which light source you're using. If you're using something with a 300 lumen output, you're probably going to have a bad time, but if you're simply just using the LED ring in FC or a smaller LED that was mentioned in another thread, I doubt anyone will rule that illegal.
Please note: I am not an inspector. Please at least run it though a spike just in case. The ability to be able to turn it off will not be a bad choice at all.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 07-02-2017, 11:35
R07-M.
I'd imagine you're planning on your team operating in the portions of the field clouded by one, or both, airships. Is your vision code not streaming a feed to your drivers to help them drive the robot in these cases?
Unread 07-02-2017, 13:52
FRC #3007
Rookie Year: 2015
The streaming code is a self-looping VI that starts when Vision Processing.vi initializes. It is separate from the actual vision loop that you write. It lies far outside the Enable Vision case structure.
Team 3007: 2017
