Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 01-02-2017, 15:19
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Help with Team 254 TrajectoryLib
Hey guys!
We were attempting to use the library and were wondering what the parameters for the construction of a waypoint are in terms of real world measurements. link here
Thanks!
Team 1403: Cougar Robotics (2015 - present)
Unread 01-02-2017, 16:48
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Help with Team 254 TrajectoryLib
https://www.chiefdelphi.com/forums/s...trajectory+254
They used inches. Units don't matter though. You get data back in the same units that you put in.
http://team2168.org
Unread 01-02-2017, 19:07
axton900's Avatar
Rookie Year: 2015
The problem I'm having is that the values I put in the waypoints don't actually result in the robot moving that distance. What I've discovered through experimentation is that if I change the max_vel, the distance the robot travels changes.
What I want is for the robot to drive 8 feet forward. The waypoints I'm using are (0, 0, 0,) and (8, 0, 0). All the values I feed into the motion mapping algorithms are in feet. The robot does not actually go 8 feet; instead it goes to a different destination depending on what Max velocity we input. Does anyone know any possible causes?
Unread 01-02-2017, 20:36
How did you tune kp, kd, kv, and ka?
