Go to Post Admiration is universal, it does not exclude those who have achieved past success. - hg273 [more]
Unread 30-01-2017, 18:59
DybbukCode DybbukCode is offline
FRC #4572
DybbukCode is an unknown quantity at this point
Exclamation Build succesful, but no robot code
This is our build console. Whenever we try to submit our code, it makes communication and the build is succesful, but the driver station still has a red light for the driver station. When I use an example program, it works. What could the problem be?
Buildfile: C:\Users\Matan\workspace\MEME-Powered\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\Matan\workspace\MEME-Powered\build
[delete] Deleting directory C:\Users\Matan\workspace\MEME-Powered\dist
compile:
[mkdir] Created dir: C:\Users\Matan\workspace\MEME-Powered\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\Matan\wpilib\java\current\lib\W PILib.jar;C:\Users\Matan\wpilib\java\current\lib\N etworkTables.jar;C:\Users\Matan\wpilib\java\curren t\lib\opencv.jar;C:\Users\Matan\wpilib\java\curren t\lib\cscore.jar to build
[javac] Compiling 11 source files to C:\Users\Matan\workspace\MEME-Powered\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\Matan\workspace\MEME-Powered\dist
[mkdir] Created dir: C:\Users\Matan\workspace\MEME-Powered\build\jars
[echo] [athena-jar] Copying jars to build/jars.
[copy] Copying 4 files to C:\Users\Matan\workspace\MEME-Powered\build\jars
[jar] Building jar: C:\Users\Matan\workspace\MEME-Powered\dist\FRCUserProgram.jar
get-target-ip:
[echo] Finding roboRIO, please ignore any [hostinfo] error messages
[echo] Trying DNS: roboRIO-4572-FRC.lan
[echo] Trying USB: 172.22.11.2
[echo] Trying mDNS: roboRIO-4572-FRC.local
[echo] Trying Static Ethernet: 10.45.72.2
[hostinfo] Error retrieving remote host information for host:roboRIO-4572-FRC.lan.
[echo] Resolved mDNS to 10.45.72.31
[echo] roboRIO found at 10.45.72.31
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
[sshexec] Connecting to 10.45.72.31:22
[sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
[delete] Deleting: C:\Users\Matan\wpilib\java\current\lib\native\lib\ WPI_Native_Libraries.properties
[scp] Connecting to 10.45.72.31:22
[scp] Receiving file: /usr/local/frc/lib/WPI_Native_Libraries.properties
[scp] Receiving: WPI_Native_Libraries.properties : 2598
[scp] File transfer time: 0.01 Average Rate: 519,600.0 B/s
[scp] done
[scp] Receiving file: /usr/local/frc/lib/User_Libraries.properties
[scp] Caught exception: scp: /usr/local/frc/lib/User_Libraries.properties: No such file or directory
[echo] [athena-deploy] Copying code over.
[scp] done.
[sshexec] cmd : ldconfig
[sshexec] cmd : killall -q netconsole-host || :
[delete] Deleting: C:\Users\Matan\wpilib\java\current\ant\netconsole-host.properties
[scp] Receiving file: /usr/local/frc/bin/netconsole-host.properties
[scp] Receiving: netconsole-host.properties : 134
[scp] File transfer time: 0.0 Average Rate: 33,500.0 B/s
[scp] done
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 10 seconds
Unread 30-01-2017, 19:28
ben47955 ben47955 is offline
FRC #3996 (RIKITIK)
ben47955 is an unknown quantity at this point
Re: Build succesful, but no robot code
What is the light in dashboard is red ?
Maybe that mean is a error in the code. Does the console in dashboard send error ?
Unread 30-01-2017, 19:49
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
I've seen this happen sometimes when there is an error in your RobotInit() - maybe check there for anything out of the ordinary, like a NullPointer or something.
Unread 30-01-2017, 19:50
generaldgibson generaldgibson is offline
generaldgibson
AKA: Daniel Gibson
FRC #3397 (FRC Robolions)
Rookie Year: 2015
generaldgibson is an unknown quantity at this point
Yes, I had this happen recently, and in the drive station there was a NullPointer indicating where the code was crashing - you'll have to change the code on that line.
Unread 01-02-2017, 15:10
FRC #4572
Exclamation Re: Build succesful, but no robot code
I looked through the cconsole in the driver station, and noticed a couple of errors. Does anyone know what they mean?
********** Robot program starting **********
ERROR 1 ERROR Unhandled exception: java.lang.RuntimeException: Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.initializePWMPort (Native Method), edu.wpi.first.wpilibj.PWM.<init>(PWM.java:61), edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java: 24), edu.wpi.first.wpilibj.PWMSpeedController.<init>(PW MSpeedController.java:23), edu.wpi.first.wpilibj.Spark.<init>(Spark.java:49), org.usfirst.frc.team4572.robot.subsystems.DriveSub system.<init>(DriveSubsystem.java:15), org.usfirst.frc.team4572.robot.Robot.robotInit(Rob ot.java:46), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:64), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:247)] edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:249)
Error at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:249): ERROR Unhandled exception: java.lang.RuntimeException: Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.initializePWMPort (Native Method), edu.wpi.first.wpilibj.PWM.<init>(PWM.java:61), edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java: 24), edu.wpi.first.wpilibj.PWMSpeedController.<init>(PW MSpeedController.java:23), edu.wpi.first.wpilibj.Spark.<init>(Spark.java:49), org.usfirst.frc.team4572.robot.subsystems.DriveSub system.<init>(DriveSubsystem.java:15), org.usfirst.frc.team4572.robot.Robot.robotInit(Rob ot.java:46), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:64), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:247)]
WARNING: Robots don't quit!
---> The startCompetition() method (or methods called by it) should have handled the exception above.
➔ Launching «'/usr/local/frc/JRE/bin/java' '-Djava.library.path=/usr/local/frc/lib/' '-jar' '/home/lvuser/FRCUserProgram.jar'»
Unread 01-02-2017, 16:10
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
I believe the part that says "Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.initializePWMPort " indicates that the PWM port you are trying to use has already been used to initialize another device. Make sure all of your motor controllers have a unique port number passed to them. Or post your RobotInit code here if that doesn't help.
Unread 01-02-2017, 16:21
FRC #4572
Here's the robotInit code:
public void robotInit() {
chooser = new SendableChooser<Object>();
driveSubsystem = new DriveSubsystem();
gyroSystem = new GyroSystem();
ballHopperSystem = new BallHopperSystem();
ropeClimberSystem = new RopeClimberSystem();
CameraServer.getInstance().startAutomaticCapture() ;
SmartDashboard.putData("Auto mode", chooser);
robotDrive = new RobotDrive(RobotMap.FRONT_LEFT_MOTOR_PORT, RobotMap.BACK_LEFT_MOTOR_PORT, RobotMap.FRONT_RIGHT_MOTOR_PORT, RobotMap.BACK_RIGHT_MOTOR_PORT);
robotDrive.setInvertedMotor(MotorType.kFrontLeft, true);
robotDrive.setInvertedMotor(MotorType.kFrontRight, true);
robotDrive.setExpiration(0.1);
Unread 01-02-2017, 16:31
FRC #4572
UPDATE: We moved a couple things around in our doe, and we are no longer getting the same error. Now we're getting:
ERROR: Could not instantiate robot org.usfirst.frc.team4572.robot.Robot!
Unread 02-02-2017, 08:58
Look at the code in each of your subsystems and note which port number your using for each motor. My suspicion is that you'll find the same port number being used in more than one place - which will cause a runtime error during initialization.
Unread 05-02-2017, 10:02
That means you renamed or moved your robot class and now the roborio can't find it.
