Go to Post I hope that kids will stop asking us if we build Battlebots and start asking us if we build Transformers. To that, I will answer with a resounding yes. - Madison [more]
Unread 01-02-2017, 17:06
riptide321 riptide321 is offline
FRC #4404
riptide321 is an unknown quantity at this point
Novice Coder Help
The robot has the code on the roboRio and is connected to the driver station. The joystick is also connected but none of the motors are firing when the joystick is moved.
Here is the code:
package org.usfirst.frc.team4404.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.Timer;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	Joystick mainStick;
	Timer timer = new Timer();
	RobotDrive drive;
	Solenoid gearDropper = new Solenoid(1);
	Spark rightMotor1;
	Spark rightMotor2;
	Spark leftMotor1;
	Spark leftMotor2;
	 * This function is run when the robot is first started up and should be
	 * used for any initialization code.
	@Override
	public void robotInit() {
		rightMotor1 = new Spark(0);
		rightMotor2 = new Spark(1);
		leftMotor1 = new Spark(2);
		leftMotor2 = new Spark(3);
		drive = new RobotDrive(rightMotor2, rightMotor1, leftMotor2, leftMotor1);
		mainStick = new Joystick(0);
	 * This autonomous (along with the chooser code above) shows how to select
	 * between different autonomous modes using the dashboard. The sendable
	 * chooser code works with the Java SmartDashboard. If you prefer the
	 * LabVIEW Dashboard, remove all of the chooser code and uncomment the
	 * getString line to get the auto name from the text box below the Gyro
	 * You can add additional auto modes by adding additional comparisons to the
	 * switch structure below with additional strings. If using the
	 * SendableChooser make sure to add them to the chooser code above as well.
	@Override
	public void autonomousInit() {
		timer.reset();
		timer.start();
	 * This function is called periodically during autonomous
	@Override
	public void autonomousPeriodic() {
	 * This function is called periodically during operator control
	@Override
	public void teleopPeriodic()
		drive.arcadeDrive(mainStick);
		boolean buttonValue, isOpen;
		isOpen = false;
		buttonValue = mainStick.getTrigger();
		if(buttonValue)
			if(!isOpen)
				gearDropper.set(true);
			else
				gearDropper.set(false);
			isOpen = !isOpen;
	 * This function is called periodically during test mode
	@Override
	public void testPeriodic() {
What is the solution to this problem?
Unread 01-02-2017, 17:50
caleby caleby is offline
FRC #1432
caleby is on a distinguished road
Re: Novice Coder Help
Do the lights on the motor controllers change colors when you move the joystick?
Have you confirmed that your PWMs are plugged in correctly?
Unread 01-02-2017, 18:00
FRC #4404
The PWM's leds flash on and off
Unread 01-02-2017, 18:08
FRC #1432
The PWM is the black, white, and red cord that goes between the roborio and the motor controller. Is it plugged in properly? The light on the motor controller should change to red or green depending on which way your joystick is.
Unread 01-02-2017, 18:15
T8PineappleSam T8PineappleSam is offline
Jonathan
AKA: Jonathan Zwiebel
FRC #0008 (Paly Robotics)
Team Role: Driver
T8PineappleSam will become famous soon enoughT8PineappleSam will become famous soon enough
I would recommend printing out the joystick values or going to the USB Devices tab in the driver station to ensure that it is giving actual values. It is possible that your joystick or USB connection is the issue.
Jonathan Zwiebel
Driver, Project Manager, Programmer [Team 8, Paly Robotics]
2016 Central Valley Regional Finalist and Wildcard, Silicon Valley Regional Quarterfinalist, Curie Division, CalGames Quarterfinalist and Entrepreneurship Award, Capital City Classic Quarterfinalist
2015 Central Valley Regional Entrepreneurship Award, Silicon Valley Regional Entrepreneurship Award, Capital City Classic Semifinalist and Judges' Award
2014 Central Valley Regional, Silicon Valley Regional, Chezy Champs
Unread 01-02-2017, 18:44
ben47955 ben47955 is offline
FRC #3996 (RIKITIK)
ben47955 is an unknown quantity at this point
isOpen = false;
		if(buttonValue)
			if(!isOpen)
			else
			isOpen = !isOpen;
isOpen will be always false, you have to put the variable global.
Check if your joystick is really in port 0 in driverStation.
Unread 01-02-2017, 20:30
Adnewhouse's Avatar
Adnewhouse Adnewhouse is online now
FRC #0639
Adnewhouse is an unknown quantity at this point
If the LED's are blinking, you might have the limit switch settings configured wrong or the PWM connection is not hooked up correctly. You should check the cable orientation and read the manual to match the blink code to the operating state of your Spark. It will also tell you how to make sure the limit switch configuration is correct in the manual. Other than the issue with the isOpen variable, your code looks correct. (Keeping in mind I'm not familiar with Java wpilib stuff)
