Go to Post Theory (n.) - A mythical place where all robot designs work. - MechEng83 [more]
Unread 01-02-2017, 11:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: small superbright green LED panels?
get a Spike relay, and use it to switch power on or off, if that's what you are trying to do.
Unread 01-02-2017, 11:07
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Originally Posted by Coach Seb View Post
Can anyone explain how to connect the LED driver to the RoboRio?
The RIO won't be able to provide enough current to drive one of these directly. If you want the ability to turn the LED on and off, you'll need to use a relay module. The only legal one is the Spike. IF you're not worried about that current draw, you can just plug them straight into the PDP.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 01-02-2017, 12:25
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
If you use the LED driver in the link I provided, connection to the RoboRio is very simple.
Because the driver is a constant current source, you can provide power to it directly from the PDB, there is no need to use a VRM to power it.
The connection to the RoboRIo is as simple as connecting the "CTRL" (D+), these are the dimmer inputs, input on the LED Driver to a digital out on the RoboRio. There is no need to connect the "DGND"(D-) as GND is provided by the power GND.
Setting the digital output low turns the LED off, and high turns it on.
EASY PEAZY!
Unread 01-02-2017, 17:40
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Spikes are no longer sold - so long as you are not using it to control motors or other actuators, you can get an off the shelf relay for controlling any sort of lights on your bot.
Unread 01-02-2017, 20:49
MrForbes's Avatar
AKA: Jim
Thanks for the update on Spikes...we have been using them for a long time, and have plenty, so I wasn't aware that you can't buy them.
Also interesting about the power supply, that makes life easy
Unread 01-02-2017, 21:11
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Depending on the current draw, you may be able to use the PCM to power these. I'd have to verify the legality of that for a competition robot thought. I believe the PCM can source around .6 amps for relays.
