Go to Post Basically, just because you CAN do something doesn't mean you should and being savvy enough doesn't entitle you to being above the law. - Greg Needel [more]
Unread 01-02-2017, 21:32
BetaBlues's Avatar
BetaBlues BetaBlues is offline
FRC #5975 (Beta Blues)
Rookie Year: 2016
BetaBlues is an unknown quantity at this point
Question Driver Station No Robot Code Connection Error
Hello everyone! We are having trouble with the FRC Driver Station. We deploy our code from Eclipse which builds fine, but then when we go to the driver station it shows red on "code connection". We cannot enable the robot to test our code. We have tried pushing older code that we know works from Github but it still isn't working. Has anyone had this problem before and what can we do?
Unread 01-02-2017, 21:35
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: Driver Station No Robot Code Connection Error
This is most likely because your code is crashing directly on boot. Check the log (RioLog) and see if it has an error. If it doesn't, there's must be an issue with deploying the code. SSH into the rio and make sure that the executable is actually on the Rio.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 04-02-2017, 14:13
BetaBlues's Avatar
Rookie Year: 2016
We are using Windows 7 to talk to the roborio. What's the easiest way to use SSH on this system? Thank you!
Unread 04-02-2017, 15:08
BetaBlues's Avatar
Rookie Year: 2016
We are able to ssh into the roborio. Where are the executable and the log file located? Thank you!
Unread 04-02-2017, 15:10
vauc2000 vauc2000 is offline
FRC #1797 (Phoenix 1797)
Rookie Year: 2016
vauc2000 is an unknown quantity at this point
One of the easiest ways to ssh into the RoboRIO would be to download PuTTY. This SSH client works on Windows, as well as other operating systems. Make sure you are connected to the RoboRIO network, and then input the robot hostname (RoboRIO-[your team number without leading zeroes]-FRC.local). For example, your hostname would be RoboRIO-5975-FRC.local.
On another note, have you renamed the Robot class? Another reason why the driver station may be providing the error of "No Robot Code" could be that you renamed the main Robot class without updating the build.properties file.
Unread 04-02-2017, 15:29
BetaBlues's Avatar
Rookie Year: 2016
We are logged in as admin. Do we need to be logged in as root to see the Riolog and the executable? We ask a lot of questions (and appreciate the answers)
Unread 04-02-2017, 15:42
Rookie Year: 2016
You should not need to be logged in as root to see the executable, admin is fine. To ensure that the executable is in place, type the command "ls /home/lvuser" and see if a file called "FRCUserProgram.jar" (if you are using Java) is in the list of filenames outputted. If you are using c++, I assume the user program would be called FRCUserProgram or something similar, but I am not entirely sure.
To check the RioLog, the simplest way would be to look at the right side of the driver station.
Unread 04-02-2017, 15:43
BetaBlues's Avatar
Rookie Year: 2016
So we found PuTTY. It's lovely <3. We are able to log into the RoboRio as admin. We don't know the password for root. We're using Java; how do we check the build.properties file?
Unread 04-02-2017, 15:49
Rookie Year: 2016
The build.properties file is on the top level of the package hierarchy in eclipse. It should appear under the folders labeled "build" and "dist".
Unread 04-02-2017, 16:03
BetaBlues's Avatar
Rookie Year: 2016
Our top tabs are as follows:
Flie
Edit
Source
Refactor
Navigate
Search
Project
WPIlib
Run
Window
Help
We are confused - where do we find the package hierarchy/folders labeled "build" and "dist"? Thank you
Unread 04-02-2017, 16:07
Rookie Year: 2016
Unless you have changed your eclipse layout, you should have a tab on the lefthand side of your eclipse window labelled "Package Explorer". In that view, you can see all of your Java projects. Click on the project you want to check, and it should expand so you can now see the files and folders in the project. Check there for the build.properties file.
Unread 04-02-2017, 16:22
BetaBlues's Avatar
Rookie Year: 2016
Thank you so much, however it looks like that is not the problem. This is what the build.properties has -> package=org.usfirst.frc.team5975.robot
robot.class=${package}.Robot
This is what we have in our robot.java file
package org.usfirst.frc.team5975.robot;
public class Robot extends IterativeRobot
Unread 04-02-2017, 16:49
Rookie Year: 2016
Ah well, it was worth a shot. Have you tried locating the FRCUserProgram on the RoboRIO yet?
Unread 04-02-2017, 17:40
BetaBlues's Avatar
Rookie Year: 2016
So it all turned out to be a coding problem lol, but your help was very useful! Thank you so much!!
Unread 05-02-2017, 20:44
Harshal Harshal is offline
FRC #4678
Harshal is an unknown quantity at this point
It could be due to mapping multiple objects to the same port. For example using the same PCM port twice in the initialization of a solenoid.
