Go to Post Little kids playing soccer....or a typical Lunacy match. Ah, memories. :cool: - Travis Hoffman [more]
Unread 27-01-2017, 23:20
truell20 truell20 is offline
FRC #5806
truell20 is on a distinguished road
Best Cameras for Computer Vision
I was wondering what are the more-popular/best-regarded cameras in the FRC community for computer vision.
My team is currently using two Microsoft Lifecams. The Lifecam maxes out at 30fps, but I don't see us needing more than that. It seems to have autofocus which is nice.
Unread 28-01-2017, 10:55
ProfessorAlekM ProfessorAlekM is offline
FRC #6190
ProfessorAlekM has a little shameless behaviour in the past
Re: Best Cameras for Computer Vision
Pretty much any logitech camera is great for openCV, the most common one being the C270. You can get wider-angle cameras but they are nearly $100, so it's usually easier to just glue a phone camera lens on for a wider FOV.
Unread 28-01-2017, 11:26
anushad anushad is offline
FRC #2876
anushad is on a distinguished road
The Pixy is really popular, and it has a bunch of code and libraries available online.
Unread 28-01-2017, 11:44
Adnewhouse's Avatar
Adnewhouse Adnewhouse is offline
FRC #0639
Adnewhouse is an unknown quantity at this point
Our team is rather fond of the Playstation Eye camera that use to be an accessory for the PS3. It costs less than ten dollars and does 60fps at 480p (also 120fps at 320p, but we've never tried that). This is pretty ideal for vision tracking. The image sensor has ridiculously large photosites, so there is very little image noise to worry about. The only downside is that they don't work on Windows systems very well without a third party driver. On the raspberry pi, it works just fine with OpenCV. You can get them on ebay because they are not made any more.
Unread 28-01-2017, 11:54
Commandman7 Commandman7 is offline
FRC #4362 (Gems Robotics)
Commandman7 is an unknown quantity at this point
Last season we had great success with the Logitech C920 / 922 / 922x. These cameras are great because they have built in H.264 Encoding, which really took a lot of stress off our vision processing hardware. In order to use the built in encoding, I had to dig up some ancient software (released 1999) in order to run it, but I'm sure there's a better solution.
Unread 28-01-2017, 12:23
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
The Kinect's IR sensor has never let us down. If you have a Jetson board available, you can use the Kinect v2 to get both IR and RGB at the same time (Kinect v2 requires USB 3.0, while Kinect v1 doesn't). Alternatively, you can use the Depth stream as a cheap-mans IR sensor.
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 28-01-2017, 21:09
cmastudios's Avatar
cmastudios cmastudios is offline
AKA: Connor Monahan
FRC #1706 (Ratchet Rockers)
cmastudios is an unknown quantity at this point
We have been able to use the Genius 120-degree (WideCam F100) for multiple years now, which has allowed us to see a greater portion of the field. We were also able to convert the camera to an IR camera by removing the glass filter inside the lens and inserting a clipping of floppy disk between the CMOS and the lens assembly. In 2014, with three of these, we were able to track the entire field, which I wrote about here. I recommend it.
Unread 28-01-2017, 21:15
AutomationFTW's Avatar
AutomationFTW AutomationFTW is offline
FRC #5829
Rookie Year: 2016
AutomationFTW can only hope to improve
Microsoft LifeCam HD-3000
https://www.amazon.com/Microsoft-Lif.../dp/B008ZVRAQS
Unread 28-01-2017, 21:47
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz will become famous soon enough
Shameless plug: If you have access to a 3d printer, I've made a minimalist mount for the LifeCam-3000 here: http://www.thingiverse.com/thing:1494829
The Microsoft LifeCam HD‑3000 is one of the most common due to its small size and low price, as well as being available from FIRSTChoice for several years.
Axis network cameras are also popular due to their many features and adjustable options.
Unread 01-02-2017, 22:41
Justin Buist Justin Buist is offline
FRC #4003 (TriSonics)
Rookie Year: 2015
Justin Buist is an unknown quantity at this point
It also doesn't work with the roboRio, at least not out of the box. We've tinkered with them a bit this year. The most promising thing, to me, about them is that you can pull the IR filter out and replace it with Mylar (or the inside of an old floppy disk) to block most visible light but let IR through.
The pi works with the camera just fine though. Had two students "struggle" with getting it to work on their Windows and Mac machines but popped it into the pi and it was just fine. Not sure why the roboRio is crippled with only supporting the "uvcvideo" kernel module and none of the other USB webcams. I could understand it if they really nailed that one down but the Wpilib documentation and interaction with v4l2 is so bad even with that limited driver support that it's almost like they didn't try and forced people to get creative.
Unread 01-02-2017, 23:29
Adnewhouse's Avatar
FRC #0639
That's a real bummer. The camera is really great on a Raspberry Pi. The sensor is superb and that IR filter hack sounds really cool. I'm guessing recompiling the kernel on the roboRio to support the camera is a no-go because of national instrument's special sauce. We have at least 4 of them floating around because they're so cheap.
Unread 02-02-2017, 08:40
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Last year we used Logitech c930e for its wide field of view
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 02-02-2017, 09:14
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
Thanks for This! Hoping to try it out soon!
2016 Greater Pittsburgh Regional Winner (With 5406 and 1559) | Finger Lakes Regional Semi-finalist
2015 Greater Pittsburgh Regional Quarter-finalist | Finger Lakes Regional Semi-finalist
Unread 02-02-2017, 13:44
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
What was the ancient software you had to dig up?
Some of us remember partying like it's 1999 by the way....
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 02-02-2017, 14:48
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
We've mounted it to our test chassis and it seems to be working well. My only complaints are that it's too short to evenly mount the LED ring (if the camera's not over the edge) and there's not much clearance between the camera and the screw holes.
