Go to Post I suggest that you don't discuss...sensitive issues about your team on this public forum. - Andy Baker [more]
Unread 02-02-2017, 08:59
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Fuel leaves behind a thin film
I have noticed that the fuel leaves a film on anything that it slides against, and each piece of fuel adds to that layer until eventually there is a pale yellow plastic film covering everything!
This film seems to reduce the effectiveness of shooter wheels by reducing their coefficient of fiction, and reduces the grip of rollers and polyurethane belts.
Our plan is to simply scrape it off after every match with fingernails and non-metal tools. stretching the polyurethane belts a bit by hand also seems to loosen up the film.
What are your thoughts on this Polyethylene film menace?
How do you plan to remove it?
How long before the fuel loses so much mass that it shoots differently?
Have you found any wheels that naturally shed this film?
Unread 02-02-2017, 09:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Fuel leaves behind a thin film
It looks like the challenge was even more challenging than we anticipated.
We are not doing fuel, so we won't worry about it.
I think that is the least of the worries for teams that are playing with fuel.
No. But haven't looked, either.
Unread 02-02-2017, 09:17
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Wheels that shed the film will be the same wheels that have an even lower coefficient of friction, particularly fluoropolymers, such as FEP, PTFE, and Viton. Silicone may work though.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
lukekaiser lukekaiser is offline
FRC #5547 (the talons)
Rookie Year: 2016
lukekaiser is an unknown quantity at this point
Our team was suggesting that we spool up our flywheel shooter, and touch some high grit sandpaper to it for a few revolutions.
Unread 02-02-2017, 09:19
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We are going to be doing a bit of experimentation on techniques to remove the film but honestly we are probably just going to be buying a ton of wheels and replacing them up to a few times an event.
pilleya's Avatar
pilleya pilleya is offline
Head Cheesecake Chef
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Yep, chances are the fuel is going to be cracked and/ or broken before the weight becomes a serious issue. The residue is a menace, but each individual ball is leaving behind very, very little.
Unread 02-02-2017, 09:31
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Embrace the residue. Let the residue become part of your shooter wheels. Then you never have to worry about cleaning it off
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 02-02-2017, 09:37
FRC #3007
Rookie Year: 2015
That would be okay if it weren't polyethylene.
Team 3007: 2017
Unread 02-02-2017, 09:38
Rookie Year: 2016
I disagree our robot has shown significant decreases in ball speed when the residue builds up. After shooting about 150 to 200 balls our grey flywheel is a nice high visibility yellow color!!!
Unread 02-02-2017, 09:56
Kartoffee Kartoffee is offline
FRC #2834
Kartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to all
I saw the same thing with the FTC particles while mentoring last year. It looks like it shouldn't cause much of an issue if your shooter wheels are moderately compliant, and in contact with the fuel for several inches of travel.
My best guess is that it happens with the initial acceleration, where the fuel is grabbed after about 2 rotations, and it's not causing an issue after it is at speed.
If you plan to be shooting a lot, either plan around it or be prepared to remove it after each match. In FTC, I found that it's easy enough to grab with your hands.
Always blame the CAD team.
Unread 02-02-2017, 10:11
MrForbes's Avatar
AKA: Jim
Sounds like you might want to make your shooter so it works well after you shoot 200 or so balls with it. That's the point he's trying to make.....if you set up your shooter so it can just barely make the shots when the wheel is new, then you're going to have trouble. You want to set it up so it shoots too far when the wheel is used and has turned yellow, and dial it back a little.
Unread 02-02-2017, 10:23
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
We have not seen this in any of our testing.
2012-Present Wave Robotics Team 2826
Unread 02-02-2017, 10:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I suspect this starts cropping up when you move from gravity feeding into a shooter wheel to controlled conveyor feeding. If you don't get the spacing right, the conveyor is still holding the fuel when it contacts the shooter wheel, and the shooter wheel slips until it gets enough grip to rip the fuel out of the conveyor. At least, that's my experience from multiwheel frisbee shooters.
Basically, anything where physics is going to force the wheel to slip at high speed on the fuel for a prolonged time is probably going to melt some of it off.
Unread 02-02-2017, 10:56
Alex Chamberlin's Avatar
Alex Chamberlin Alex Chamberlin is offline
Gaff tape and love
AKA: Guy in the white hat
FRC #2521 (SERT)
Team Role: Tactician
Rookie Year: 2015
Alex Chamberlin is an unknown quantity at this point
Try acetone or benzene.
Chris is me's Avatar
AKA: Pinecone
This is an issue for every single kind of shooter wheel, intake mechanism, etc. that we've tested. Some tips:
1. Coarse sandpaper, with pressure and motion applied parallel to the axis of rotation (i.e. left to right) will quickly (albeit, not easily) strip off this material.
2. Some material retains their traction qualities better than others when coated with this clear stuff. Think about the different factors that cause adhesion beyond just if the rubber is grippy or not, such as compliance. Big hint there.
3. Get the RPM right for your wheels. The more slippage between the ball and the wheel, the worse the wear is going to be. Everyone who did Frisbees in 2013 knows this. So if you're relying on over-driving your wheel open-loop and just taking the speed loss, you're doing it wrong.
4. Load the shooter as fast as your mechanism can justify. The less speed differential between your ball speed at the indexer and your ball speed at the shooter, the less material gets stuck due to lower slippage. (Of course, there may be more material on your indexer surface, but that's less of a big deal)
5. Pick kids for pit crew who love sanding things.
