Go to Post You valuable advice has prevented me from killing myself and others numerous times =) - Stephen Kowski [more]
Unread 01-02-2017, 00:51
rtrahms's Avatar
rtrahms rtrahms is offline
FRC #1778 (Chill Out!)
rtrahms is a jewel in the roughrtrahms is a jewel in the roughrtrahms is a jewel in the rough
Intermittent Sendable Chooser output on Smart Dashboard
Hi all -
We use the SendableChooser class for creating our autonomous options:
chooser = new SendableChooser();
chooser.addDefault("DO_NOTHING", DO_NOTHING);
chooser.addObject("DRIVE_FORWARD", DRIVE_FORWARD);
chooser.addObject("DEPOSIT_GEAR_LEFT", DEPOSIT_GEAR_LEFT);
chooser.addObject("DEPOSIT_GEAR_CENTER", DEPOSIT_GEAR_CENTER);
chooser.addObject("DEPOSIT_GEAR_RIGHT", DEPOSIT_GEAR_RIGHT);
chooser.addObject("DRIVE_AND_SHOOT_BLUE_LEFT", DRIVE_AND_SHOOT_BLUE_LEFT);
chooser.addObject("DRIVE_AND_SHOOT_BLUE_CENTER", DRIVE_AND_SHOOT_BLUE_CENTER);
chooser.addObject("DRIVE_AND_SHOOT_BLUE_RIGHT", DRIVE_AND_SHOOT_BLUE_RIGHT);
chooser.addObject("DRIVE_AND_SHOOT_RED_LEFT", DRIVE_AND_SHOOT_RED_LEFT);
chooser.addObject("DRIVE_AND_SHOOT_RED_CENTER", DRIVE_AND_SHOOT_RED_CENTER);
chooser.addObject("DRIVE_AND_SHOOT_RED_RIGHT", DRIVE_AND_SHOOT_RED_RIGHT);
SmartDashboard.putData("Auto_Mode_Chooser", chooser);
When we start up smart dashboard, these options appear, and work... most of the time. Sometimes when we start smart dashboard, the options are not present. Restarting the dashboard once or twice is usually all it takes, but this looks to be a 'missed transaction' between the robot and the driver station. Has anyone had a similar experience? If so, how did you solve it?
Thanks.
Software Mentor
FRC Team 1778 - Chill Out!
Mountlake Terrace High School
Unread 01-02-2017, 01:10
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Intermittent Sendable Chooser output on Smart Dashboard
NetworkTables should sync on startup, so one dashboard restart should be all you need. Are you using 1.0 or SFX?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 01-02-2017, 08:59
rtrahms's Avatar
We're using 1.0.
Yes, most single restarts get it, but I seem to recall sometimes needing two. It also seems more common than I am comfortable with.
Software Mentor
Unread 01-02-2017, 09:18
Is this occurring on fresh starts of the Dashboard with the same Robot Code or are you seeing this when you modify the list of available options? If it's the latter, you may be running into https://github.com/wpilibsuite/SmartDashboard/issues/71
Unread 02-02-2017, 09:03
rtrahms's Avatar
This is occurring on a fresh start of smart dashboard. I haven't made any changes to sendable chooser in a while.
Software Mentor
Unread 02-02-2017, 11:33
Oblarg Oblarg is online now
AKA: Eli Barnett
Yeah, SmartDashboard has never been particularly reliable. I wholly recommend physical switches for autonomous routine selection.
"The breakfast of champions!"
Unread 02-02-2017, 13:03
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Improvements have been made this year to increase the reliability of the SmartDashboard. If you make a selection while the robot is disconnected, the SmartDashboard will send this selection to the robot when it connects.
There is an open PR right now to fix SendableChoosers not showing up:
https://github.com/wpilibsuite/SmartDashboard/pull/72
