Go to Post Let's not complain when we are getting magnificent items in the kit that teams just a few years ago could only wish for. - sanddrag [more]
Unread 02-02-2017, 11:46
rlance rlance is offline
FRC #5550
rlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to behold
Re: Most Graceful Mecanum Robots?
Originally Posted by Andrew_L View Post
Here is a control scheme for omnidirectional robots that I developed earlier that, in my opinion, gives the driver the most useful control over the robot's position and orientation: https://docs.google.com/document/d/1...it?usp=sharing
I'd be happy to answer any questions about it.
What is the "Moon Maneuver"???
We are doing omni this year and are considering adding a button for a pre-programmed evasive maneuver. Is this one of those?
Unread 02-02-2017, 11:53
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
We used a flight simulator type of joystick for our recycle rush Mecanum Drive. This enables you to control both direction, and rotation (via twist) simultaneously and intuitively. You could use this method for either field centric or robot centric control.
Logitech 963290-0403 is a very reasonably priced PC USB option.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 02-02-2017, 12:12
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Originally Posted by Chris is me View Post
For a game like this one, I like having the option to switch between the two mid-match - dip into field centric for fine adjustments and robot centric for long sprints. But this of course requires even more training to be good.
Or have one driver trained with field centric and one trained with robot centric and switch control between the two as needed.
Unread 02-02-2017, 12:16
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
A moon maneuver is a move in which you "orbit" around a fixed point, often an opposing robot, while facing that point at all times, much like the moon orbiting the Earth.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 02-02-2017, 12:21
Chris is me's Avatar
AKA: Pinecone
I'm not sure if you're joking, but this is a completely ridiculous idea. This is almost guaranteed to give you worse performance than giving the same driver double the stick time, and the speed lost in switching drivers mid-match completely negates the relatively minor speed advantage of switching between the styles of drive. Don't do this.
Unread 02-02-2017, 12:56
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
You can also train your drivers to operate a field centric controls in the "tank drive direction" when going on long sprints. It's just a matter of remembering to turn and pointing in the right direction.
With a bit of feedback control, you should be able to assign a button on the controller to "sprint mode" where driving is still field-centric, but the robot always drives with the front forward. I haven't tried it before, but that should give you the sprinting speed of robot-centric with the ease of control of field-centric.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 02-02-2017, 12:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I was staying away from this thread until this. I love driving this maneuver in video games and robot demos. It's pretty fun. However, have yet to see it give an advantage in any FRC match videos.
This year Mecanum seems to give the most advantage during line up of receiving a gear and placing a gear. In field-centric mode, it does so by increasing margin of error and intuitiveness to do those tasks. The most graceful Mecanum bots this year will do just that, IMO. Juke moves with Mecanum under-perform 9 times out of 10.
In my experience, Mecanum doesn't seem to reduce the time it takes to do those tasks when compared to a practiced driver on a tank. Time is the differentiator in everything at high levels of play. I'd even say that a tank drive which sprints 16-18ft/s during the straightaways and shifts to a 6-7ft/s low gear for the line-up would still be a faster cycle time than a Mecanum drive at an overall 12-13ft/s.
So "graceful" Mecanum bots who can score well in a reasonable amount of time may find a home on my alliance in early events simply because I set goals for my team to do so well at our singular role that the Mecanum bot will be largely undefended. Or maybe I get that Mecanum bot on my alliance in order to absorb the defense since they're so easy to defend. Who knows .
2017 Scoring Model
CAD Library | GitHub
Unread 02-02-2017, 13:02
Not joking, that is the control scheme we are currently planning to implement.
We still have plenty of time to abort if we discover this is more trouble than it is worth.
Unread 02-02-2017, 13:04
Originally Posted by Greg Marra View Post
What are some of the most graceful examples of mecanum robot driving in the past?
None.
Unread 02-02-2017, 13:50
RoboChair's Avatar
AKA: Devin Castellucci
Originally Posted by Tom Bottiglieri View Post
None.
Something about "Going sideways is a waste of time"?
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 02-02-2017, 14:33
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud of
None.
I agree that we really haven't seen a perfect example YET on how you should drive mecanums but with the constant bashing of the drivetrain ( of people who never even tried it might I add ) it's going be hard to get there.
Learn something, Know Something, Do something
Unread 02-02-2017, 14:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This, only I think it'd be better to have it pick the closest of forwards/backwards. Or maybe have that toggleable. It should be straightforward to implement. Hold down the print button, lock out rotation input, apply fixed amount of rotation command CW or CCW in direction of travel based on commanded vector and your current heading. Probably scale it down once you get very close to the correct heading, but capping it to a reasonable amount would probably make driving more stable for large corrections.
Field centric tank drive implemented in this fashion would be an interesting innovation.
Unread 02-02-2017, 14:52
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Can't tell if you're talking in general, or trying to call out 254 on having never tried an omnidirectional drivetrain. If the latter, I'd be immensely surprised if they've never dabbled with it in offseason. I assume their on field performance with a WCD needs no justification.
Academic Student (Forever)
Unread 02-02-2017, 15:05
We are implementing this in our code this year, I had this same idea a few years back but haven't had a chance to implement it until now.
Strafing can be pretty useful in many situations, but it is an awful choice for travelling long distances quickly.
Unread 02-02-2017, 15:52
NolanGZ3452's Avatar
NolanGZ3452 NolanGZ3452 is offline
FRC #3452 (GreengineerZ)
Team Role: Driver
NolanGZ3452 is an unknown quantity at this point
I might be bias because this is my own team, but i beleave we got the most our of our mecanum drivetrain in 2015. I know its not the same because the games are so different, but i believe if you go with a mecanum drivetrain you need to use its abilities to your advantage or else you might as well just have gone with tank drive.
https://www.youtube.com/watch?v=7FJLMB58eVU
