Go to Post Parking Lot T-Shirt Bootleggers are NOT approved suppliers - Rich Kressly [more]
Unread 02-02-2017, 12:52
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
SRX Motion Profiling Control
In this example, and in the documentation, we're told that we should run
_talon.processMotionProfileBuffer();
about twice as fast as the duration of our trajectory points.
I'm just curious why this is implemented this way. If I'm running a trajectory point every 20ms, why do I need to tell the Talon to process its points every 10ms?
I'm not asking about the timing, but more why the talon needs to be notified instead of processing the buffer on its own. I'm sure I'm missing something, but I would have expected to be able to tell the Talon to start processing its buffer, and then check to see if it's done.
Unread 02-02-2017, 12:54
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: SRX Motion Profiling Control
Why I gotta tell the talon to do the thing?
Unread 02-02-2017, 15:55
Tyler Scheuble Tyler Scheuble is offline
Programming Lead
FRC #2471 (Team Mean Machine)
Tyler Scheuble is an unknown quantity at this point
Good question... I would love to know the answer for this as well.
Unread 02-02-2017, 16:52
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
We could have baked in a thread task into the CANTalon class, but I thought this would be a simple way to ensure there are no reentrancy or other thread-related issues without requiring much more testing/complexity.
I also did not want teams scapegoating a talon thread as the reason why their heavily threaded FRC program is not working or why their CPU utilization is high.
Additionally we did not want to assume what the correct frequency to call was, however the function itself is pretty fast (does not considerably block).
This could change in the future. I figured only advanced users would use motion-profile, and most users would use motion-magic since you don't need to create a profile by hand (instead you set PIDF gains and cruisevel/accel to quickly get motion control).
Unread 02-02-2017, 17:06
Robotics Engineer
Thanks for the quick reply. Would this even have to be baked into the class? Would it be possible to do this logic entirely on the talon? Maybe then the API would be something like:
_talon.setMotionProfileUpdateRate(int ms)  //tells the talon how frequently to process its motion profile buffer.
_talon.startProcessingMotionProfile() //tells the talon to start processing its motion profile buffer.
Then we could use _talon.getMotionProfileStatus(_status); to determine if the MP has finished running.
One of the Talon's greatest advantages is the parallel processing it brings to FRC. If I could give a talon a MP, tell it to follow it, and check back in to determine when its done, I'd be sooooo happy.
Unread 02-02-2017, 17:15
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
T
Why not just calculate the rate by dividing the delta time on the points in the profile by 2? Most users will get it right but why make them supply a value that could be determined automatically.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 02-02-2017, 17:47
ozrien's Avatar
Omar Zrien
AKA: Omar
That is how it works. But if your MP is large then it can't be sent all at once. Instead it has to be streamed into the Talon as it executes, granted there is buffering in all the spots you would expect. The process function manages this periodically.
