Go to Post With a little time and practice, I think that most people would find that there is no magic involved in programming. - Dave Scheck [more]
Unread 02-02-2017, 16:51
elijah1111's Avatar
elijah1111 elijah1111 is offline
FRC #4601 (Circuit Birds)
Rookie Year: 2015
elijah1111 is an unknown quantity at this point
Question Open CV help
Hey anybody got any ideas on Open CV? We were planning on using it for auto gears.
static void VisionThread(){
//blah blah set up cameras
while(true){
inRange(mat,cv::Scalar(0,100,0),cv::Scalar(100,255,100),mat)//find green light
cv::findContours(mat,contours, CV_RETR_EXTERNAL, CV_CHAIN_APPROX_TC89_KCOS);//find reflect tape
			cv::drawContours(mat,contours,-1,cv::Scalar(255,255,255),1,8);//draw them
cameraserver.putframe(mat);//put the modifed image matrix
centerpoints.read()//I need to find the centerpoints here how would I do that?
void RobotInit(){
std::thread camthread(VisionThread);//makes a new thread
camthread.detach();//snaps the thread off to do its own thing
void AutonomousPeriodic(){
 camera.read()//Here is where I need help how do I get the two threads to talk
Anybody got any suggestions? I was thinking if you could calculate the distance between the two center points and you know the actual distance you can find out how far you are from the peg for the gear.
Thanks,
Elijah
4601
P.S. actual code is here https://github.com/CircuitBirds-FRC4601/CB5
Unread 02-02-2017, 17:04
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Open CV help
My biggest concern with this approach is that the gear itself will be covering those two pieces of retro tape most of the time when aligned. Encoders might be a better approach.
Unread 02-02-2017, 17:16
elijah1111's Avatar
Rookie Year: 2015
Re: Open CV help
I agree, if you get to start in front of the peg facing the wall, but what about the other ones? You would need to preset it in a certain location which seems harder this year.
Unread 02-02-2017, 17:23
elijah1111's Avatar
Rookie Year: 2015
Re: Open CV help
what do you mean by covering them? I was thinking of finding the distance between the tape before you put the gear on then reading encoder counts for that distance.
Unread 02-02-2017, 17:28
billbo911's Avatar
Re: Open CV help
Now that just might work. You would just need to have some way to tell the RC when to lock in the distance.
Unread 02-02-2017, 17:45
elijah1111's Avatar
Rookie Year: 2015
Re: Open CV help
Yah, that is my problem I'm pretty sure I open cv has the capability for doing that but how do I pass it to the auto code, because its a static void for the multi threading.
Unread 02-02-2017, 18:38
Maxcr1's Avatar
Maxcr1 Maxcr1 is offline
AKA: Max D
FRC #2169 (KING TeC)
Maxcr1 is an unknown quantity at this point
Re: Open CV help
The secret to using vision for Steamworks is having an angle of attack of the camera to avoid the gear getting in the way of seeing the tape. The vision is possible and the calculations do exist, and aren't too bad if you follow 254's presentation.
Vision Presentation
Multithreading is often unrealistic because all of the tasks have to be run in a linear pattern, and while running multiple versions can be effective, it causes issues with multiple threads fighting over the same frame. You can use a lock, but that requires Python and that can be another issue
Unread 02-02-2017, 18:52
elijah1111's Avatar
Rookie Year: 2015
Re: Open CV help
Vision Presentation
By frame do you mean the image? The multithread would be linear, there is only one thread for camera. I just need the auto to tell that thread to find the distance between the center points then relay it back to convert to encoder values. I am multithreading because the open cv capture and operations would bog down the robot. Of course I could always just take a still image of the tape but i figured it would be better to take a video to average out the distances.
