Go to Post As usual, I mistakenly look for a technical solution to a social problem. - MrForbes [more]
Unread 02-02-2017, 18:38
Maxcr1's Avatar
Maxcr1 Maxcr1 is offline
AKA: Max D
FRC #2169 (KING TeC)
Maxcr1 is an unknown quantity at this point
Re: Open CV help
The secret to using vision for Steamworks is having an angle of attack of the camera to avoid the gear getting in the way of seeing the tape. The vision is possible and the calculations do exist, and aren't too bad if you follow 254's presentation.
Vision Presentation
Multithreading is often unrealistic because all of the tasks have to be run in a linear pattern, and while running multiple versions can be effective, it causes issues with multiple threads fighting over the same frame. You can use a lock, but that requires Python and that can be another issue
