Go to Post Didn't you know, I can be in two places at once? - Andy Baker [more]
Unread 14-01-2017, 12:42
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus of 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
GRIP code generating with NetworkTables
I was playing with GRIP and the code generation for this year. Looking at the code it generated it is ignoring publishing the data. When having it use NetworkTable publishing and not the code it output is identical and does not include any imports for publishing to a NetworkTable. Is this a limitation of the code generation in the current version of GRIP or am I doing something wrong? Ideally I would like to be able to run the code on an external computer and use the NetworkTable to pass the information to the roboRIO.
FRC Drive: Play Store FRC Manager: Play Store
Unread 02-02-2017, 18:53
Denchief1 Denchief1 is offline
FRC #4398
Denchief1 is an unknown quantity at this point
Re: GRIP code generating with NetworkTables
I am having this same problem and I have installed networktables with gradle already.
Unread 02-02-2017, 19:50
SamCarlberg's Avatar
SamCarlberg SamCarlberg is online now
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
GRIP doesn't generate any publishing functions because it has no way of knowing how the generated code will be used. It's up to you to write the code that takes the output GRIP gives you and publishes it the way you want. Take a look at the GRIP code generation repository for some examples.
WPILib
GRIP, RobotBuilder
