Go to Post You don't need to prototype everything, just the stuff you want to work. - JVN [more]
Unread 02-02-2017, 21:31
Justin Buist Justin Buist is offline
FRC #4003 (TriSonics)
Rookie Year: 2015
Justin Buist is an unknown quantity at this point
Re: Best Cameras for Computer Vision
Originally Posted by Adnewhouse View Post
I'm guessing recompiling the kernel on the roboRio to support the camera is a no-go because of national instrument's special sauce. We have at least 4 of them floating around because they're so cheap.
It's all GPL code for the kernel, so there's no secret to it. I forget what kernel version the roboRio is running this year but it has to be one of these branches: https://github.com/ni/linux/tree/nilrt_pub/16.0/4.1
I think it's the 4.1 one but not sure. It's do-able, but tossing a pi in the mix and using NetworkTables to toss relevant vision data back to the roboRio sounds less risky.
Just my two cents.
Unread 02-02-2017, 22:36
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz will become famous soon enough
Originally Posted by bobbysq View Post
We've mounted it to our test chassis and it seems to be working well. My only complaints are that it's too short to evenly mount the LED ring (if the camera's not over the edge) and there's not much clearance between the camera and the screw holes.
The hole spacing is completely arbitrary and just copied what was already drilled into the frame. I'm working on a V2 with more mounting options as we plan to replace our Axis IP cameras with them.
Unread 04-02-2017, 13:27
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
That's a real bummer. The camera is really great on a Raspberry Pi. The sensor is superb and that IR filter hack sounds really cool. I'm guessing recompiling the kernel on the roboRio to support the camera is a no-go because of national instrument's special sauce. We have at least 4 of them floating around because they're so cheap.
They're not UVC based cameras so they need special drivers in the Linux kernel. I'm not sure if you can add modules on the Roborio, but in theory it would be possible to get it working with the kernel source and a crosscompiler.
