Go to Post IMHO, [the driver's] job is to drive the robot. The coaches job is to monitor everything in a match that isn't your robot. - CalTran [more]
Unread 02-02-2017, 11:11
cnc4 cnc4 is offline
FRC #2231 (OnyxTronix)
Rookie Year: 2015
cnc4 is an unknown quantity at this point
CANTalon are broken since 2.2 frimware
Hi all, while trying to debug a problem with the talons srx I found my self updating them to the latest image.
Now doing set once will work for a sec.
When I do set(-1) in a loop (execute) they blink red but also orange randomly, if I print get() it will print 0 randomly.
I am using java.
wtf is going on here? Please help!
Unread 02-02-2017, 11:15
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: CANTalon are broken since 2.2 frimware
I am using java.
Is it possible that you are sending controls from multiple locations?
Unread 02-02-2017, 11:17
Did you recheck/reset the Talon IDs once you'd updated the firmware?
Unread 02-02-2017, 11:28
Rookie Year: 2015
Thanks! I would of said no because I already checked that and because it started happening only after I reimage them.
But apparently SafetyEnabled in the RobotDrive coused it to happened.
Unread 02-02-2017, 11:39
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
You mean firmware 2.20 right?
If this is true then you should be seeing a driver station message indicating this. See section 16.14 for more information in the Talon SRX Software reference manual.
I would recommend following the debugging steps in section 16 where applicable.
There are no reported issues with 2.20 so I suspect the issue is something else.
Use the web-based config and self-test to see what state the Talon is when it's behavior is not matching your expectation (section 2).
Unread 02-02-2017, 19:20
Rookie Year: 2015
Well I got lots of warnings that are saying that there is not enough output refresh or something like that. After disabling this I noticed it went away, now it's explains why.
Well I realy did, I did not saw it. Thanks
Well the problem got solved, even the problem I debugged before (the reason I reimaged the talons) got fixed so I can totally approve you, Thanks!
Unread 02-02-2017, 19:56
Rookie Year: 2015
Can you tell me what is the difference between those options:
configMaxOutputVoltage
configNominalOutputVoltage
configPeakOutputVoltage
Unread 02-02-2017, 22:38
ozrien's Avatar
Omar Zrien
AKA: Omar
Please read Section 10.5. Peak/Nominal Closed-Loop Output in the Talon SRX Software Reference Manual.
configMaxOutputVoltage(x) is a carry over from the old Jaguar interface. Underneath it just calls configPeakOutputVoltage(x,-x).
All three APIs only affect the closed-loop modes inside Talon.
Unread 03-02-2017, 01:12
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
You can also see the red/orange or green/orange thing happen if your network is getting slammed by say something like the school network for some reason. I would recommend running hard wired to see if the issue still happens. If it does, maybe by a 5 Ghz USB adapter for your laptop and connect over 5 Ghz instead of the 2.4
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
