Re: Adjustable Shooter
Neither. I like the idea of a single shooting position at a single constant speed.
Our autonomous will have adjustible shooter speed. However, for the remainder of the match we will run with the exact same configuration and will shoot using a hard stop. We don't have the programming capability to build a reliable adjustible shooter.
We can change angle, point of release, compression etc outside of the match though. Depending on strategy we may switch configurations. Last edited by Valkonn : 03-02-2017 at 00:10. |
I concur. Repeatability is key.
Our prototyping showed that it's only about 1/4th inch range or so that you need to move the trailing edge of a wheeled shooter backboard in order to aim the shot well. We will be adjusting both
Turreted full court shooter that shoots between 5 and 30 bps based on range. Move over 1717!
Sadly I cannot divulge our true master plan OF DOOM! They will hunt me down. Come back in 3 weeks. . |
#7
Only 30 bps? Aren't you forgetting it's Chief, and everyone is doing 30 bps at 90% accuracy from full court? Are you guys tired of getting to Einstein or something? /s
#8
It's just not the same this year.
#9
Wait, we're allowed to shoot the gears now?
