Go to Post "Why use a CNC when you can get it done with wood, duct tape, and zipties!" - gcgeobuff [more]
Unread 31-01-2017, 20:57
Beans Beans is offline
FRC #4461
Beans is an unknown quantity at this point
(How to fix) Timeout waiting for radio (FRC Radio Config Utility)
Hey! Robot programmers!
Got a "Bridge firmware loaded failed: Timeout waiting for radio. Make sure sure you have launched the .exe not the .jar. Try using a switch. Please reset the bridge and try again." Error?
Well we found a fix!
1. Open the Radio Config Utility folder. Should be in C:\Program Files (x86)\FRC Radio Configuration Utility
2. Launch "FRC Radio Configuration Utility.exe"
3. Select ethernet as network interface (Make sure your wi-fi card is disabled)
4. Input team number
Radio: OpenMesh
Mode: 2.4GHz AP
(Everything else change to your likings)
*IMPORTANT* MAKE SURE YOUR ROUTER DOES NOT HAVE POWER BUT, ETHERNET CABLE IS CONNECTED TO THE COMPUTER (PLUG IN 802.3af POE)
Our team struggled here because we had the power plugged in.
5. At this point, you should only have the ethernet cable plugged in to the router. All lights should be off.
6. Click "LOAD FIRMWARE"
7. After it gives you this prompt:
"Preparing to load firmware
1) Plug the radio Ethernet ubti the PC,
2) Apply (or cycle) power to the radio.
3) If the power LED blinks, power cycle again."
Plug in the power to the router
8. Wait for it to be done flashing and press ok.
It should work. If it doesn't comment below your error. And we'll try to help you.
Unread 31-01-2017, 21:03
FRC #4461
Re: (How to fix) Timeout waiting for radio (FRC Radio Config Utility)
At step 7 its Plug the radio Ethernet into* the PC,
Unread 01-02-2017, 17:33
Benson3292 Benson3292 is offline
FRC #3292
Benson3292 is an unknown quantity at this point
We have the same issue and we still got that time our error. Any thoughts what to try next?
Unread 01-02-2017, 18:13
FRC #4461
Hi, if you followed all the steps and still got the error, I would like to verify a few things:
1. Are you guys using the AC version of the router? (OM5P-AC)
2. Are you using the ethernet cable that came with the package?
3. Is your wifi adapter disabled?
Go to Control Panel > Network and Internet > Network and Sharing Center > On the left side select "Change Adapter Settings" > Right-click your wifi adapter and disable it.
(It's because if the wifi adapter is on, it may interfere with the ethernet settings)
And the possible things that you could try are:
1. Only set the team number, Radio: OpenMesh, Mode: 2.4GHz AP and leave everything else to default.
2. Try to launch the "FRC Radio Configuration Utility.jar"
Unread 02-02-2017, 16:47
FRC #3292
What we end up getting is it will say radio found flashing firmware. Then after a few minutes we end up getting te following message. Bridge firmware load failed: timeout flashing radio. Make sure you not to unplug the radio until the operations comempletes. Please reset the bridge and try again.
Unread 02-02-2017, 20:09
FRC #4461
So what we think that you should try, is to use a switch. Basically, it lets the connection last longer during the firmware flash
Unread 03-02-2017, 07:08
npetrie3 npetrie3 is offline
FRC #0135 (Penn Robotics)
Team Role: Electrical
npetrie3 is an unknown quantity at this point
Yes this needs to be added to this post it is what ended up working for our team.
