Go to Post I guess what I am trying to say is that GP is inside all of us just waiting for a chance to escape. I am sure how the virus spread. I put the blame solely on the shoulders of Chief Delphi. - Ken Loyd [more]
Unread 03-02-2017, 13:34
DurT1178 DurT1178 is offline
FRC #1178
DurT1178 is an unknown quantity at this point
SRX Encoder not working
Hello Everyone! We are having trouble getting the encoders on our CANTalons to work properly. We are using four CANTalon SRX as our drive train with one talon to each sim. We are programming in Java, and are trying to use the getEncoderPostion method from the CANTalon class; however, it is not working. We have tried to send the values to SmartDashboard, and when we do they are continuously set to 0. We used a similar setup last year. Was something changed in the CANTalon classes? Also is there a better version of the CANTalon Javadocs? Becuase the one on the Cross The Road Website does not have detailed information on everything. Any advice is appreciated. Thanks!
Unread 03-02-2017, 13:53
dardeshna's Avatar
dardeshna dardeshna is offline
Build Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is an unknown quantity at this point
Re: SRX Encoder not working
Can you specify the model of your breakout boards and encoders? It could very well be the same issue we had - lack of pullup resistors.
Unread 03-02-2017, 13:58
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
You can use the web interface of the roboRIO to view what's going on with your Talons. It's a quick way to see if you're getting encoder readings or not. Manually moving the motors should show encoder value changes in the web interface.
Unread 03-02-2017, 14:04
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
https://github.com/CrossTheRoadElec/FRC-Examples
CTRE Examples on GitHub.
The sooner we get behind schedule, the more time we have to catch up.
Unread 03-02-2017, 14:17
FRC #1178
Where do we look to find out the model of our breakout board. Also we are trying to use the built in encoders on the Talon SRX's, do they have a model number?
Web interface says that the talons have a position and velocity of zero.
Unread 03-02-2017, 14:25
T8PineappleSam T8PineappleSam is online now
Jonathan
AKA: Jonathan Zwiebel
FRC #0008 (Paly Robotics)
Team Role: Driver
T8PineappleSam will become famous soon enoughT8PineappleSam will become famous soon enough
The Talon SRX can not get positional data without an external encoder plugged in. In order to receive sensor data you will need to plug an external sensor to the Talon's data port. (This is found on the top and covered by a plastic shield).
Jonathan Zwiebel
Driver, Project Manager, Programmer [Team 8, Paly Robotics]
2016 Central Valley Regional Finalist and Wildcard, Silicon Valley Regional Quarterfinalist, Curie Division, CalGames Quarterfinalist and Entrepreneurship Award, Capital City Classic Quarterfinalist
2015 Central Valley Regional Entrepreneurship Award, Silicon Valley Regional Entrepreneurship Award, Capital City Classic Semifinalist and Judges' Award
2014 Central Valley Regional, Silicon Valley Regional, Chezy Champs
Unread 03-02-2017, 14:26
dardeshna's Avatar
Build Captain
AKA: Devin Ardeshna
Rookie Year: 2015
There has to be a physical encoder attached to the mechanism that is rotating. The talons themselves cannot record position without the sensor. Do you have an encoder built into your gearbox?
Unread 03-02-2017, 14:28
Jonathan
Team Role: Driver
The setup we used for out drivetrain had one CIMCoder for each side with the sensors plugged in to am-3281 breakout boards (http://www.andymark.com/product-p/am-3281.htm). The breakouts plug into the data port and interface well with the CIMCoder's quadrature output.
Jonathan Zwiebel
Unread 03-02-2017, 14:33
Bob Steele's Avatar
AKA: Bob Steele
Are you using the new version of the CIM Coder or the older version?
The new one came out just a couple of weeks ago.
The old one requires a pull up resistor to be installed.
The new one has that incorporated.
oops I just realized that you guys are not the ones having problems...It was team 1178... I am sure you know what you are doing.
:0)
