Go to Post Winning the robot part of the competition is not about learning or doing unneccesary work. It works just like "winning" in industry. - Max Lobovsky [more]
Unread 03-02-2017, 14:17
DurT1178 DurT1178 is offline
FRC #1178
DurT1178 is an unknown quantity at this point
Re: SRX Encoder not working
Originally Posted by dardeshna View Post
Can you specify the model of your breakout boards and encoders?
Where do we look to find out the model of our breakout board. Also we are trying to use the built in encoders on the Talon SRX's, do they have a model number?
Originally Posted by dvanvoorst View Post
You can use the web interface of the roboRIO to view what's going on with your Talons. It's a quick way to see if you're getting encoder readings or not. Manually moving the motors should show encoder value changes in the web interface.
Web interface says that the talons have a position and velocity of zero.
