Re: Climb Stopping Mechanism
This shouldnt be too hard.
Once you see the light go on, dont drive the lift anymore. We plan to use a simple ratchet to prevent it from backdriving. |
If not, what keeps you from effectively clamping onto the field when waiting the 1 second? |
Sorry, I'm slow. I dont quite follow?
When you hit the wall on top, your motor will go to stall (unless you're current limiting) and push very hard on the top.
Now imagine everything in the system is a spring, you're going to compress/stretch parts of the robot/field and load everything up. Now there is a ratchet on there preventing you from backdriving (and you can't go forward any more as you're already loaded pretty firm into the field). Now that's how you lock yourself onto the field. |
You won't be able to release weight tension as you're literally clamping the field. Can't go the other way because of the ratchet as well.
#7
Prepare to be disappointed. There's nothing special about the scenario Adam has outlined. Any system with a ratchet and pawl is going to behave exactly as he's explained. We had this happen multiple times in 2010 with our kicker and our hanger. It's a HUGE PITA when it happens. We had to use a giant flat head screwdriver and apply major force to the pawl to lever it to disengage. This is assuming you have a pawl that's actually accessible. If you're using a ratcheting wrench you're totally screwed.
Imagine trying to release a ratchet strap that has been ratcheted to significant tension. If you try to pull the release with your fingers without taking up some of the load with the handle, you will never get it undone. You have to release tension off the release bar in order to move it. This is exactly what will happen in the scenario outlined above. |
#9
It is legal to remove the rope from the field without removing the robot from the rope. So couldn't you have two team members support the robot, while another team member releases the rope from the davit?
#10
No. Read the above. You have nowhere to support the robot to. You can't force it up because it's already pushed the touch pad to it's hard stop. The rope will be under hundreds of pounds of tension at that point. You cannot push the robot higher and therefore cannot relieve the tension.
#11
I do recall your 2010 robot and didnt realize you had those issues also. |
#12
Read what I posted again, you're literally champing the field and that rope will be under significant tension. Good luck.
#13
Or we can also do the other suggestion earlier with the current draw. Lots of time left to figure this out since our climber already made and it works. |
#14
Interesting point. How is 973 dealing with this?
#15
If you have a ratchet and are planning on stalling against the top for the full second, it needs to be able to disengage under load OR you need some way to remove the load.
