Go to Post I once heard someone say that Dean is "building an army of engineers." I disagree. I think he is building an army of the informed. - Gope [more]
Unread 03-02-2017, 15:37
AdamHeard's Avatar
Lead Mentor
Re: Climb Stopping Mechanism
Originally Posted by waialua359 View Post
This shouldnt be too hard.
Once you see the light go on, dont drive the lift anymore.
We plan to use a simple ratchet to prevent it from backdriving.
Will you have the ability to disengage the ratchet under load?
If not, what keeps you from effectively clamping onto the field when waiting the 1 second?
Unread 03-02-2017, 15:58
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Sorry, I'm slow. I dont quite follow?
Unread 03-02-2017, 16:05
AdamHeard's Avatar
Lead Mentor
When you hit the wall on top, your motor will go to stall (unless you're current limiting) and push very hard on the top.
Now imagine everything in the system is a spring, you're going to compress/stretch parts of the robot/field and load everything up.
Now there is a ratchet on there preventing you from backdriving (and you can't go forward any more as you're already loaded pretty firm into the field).
Now that's how you lock yourself onto the field.
Unread 03-02-2017, 16:12
waialua359's Avatar
AKA: Glenn
In 2010, we created a simple ratchet pawl system that worked for our climber. It should release if we at least carry the robot, releasing weight tension.
Unread 03-02-2017, 16:15
AdamHeard's Avatar
Lead Mentor
You won't be able to release weight tension as you're literally clamping the field. Can't go the other way because of the ratchet as well.
Unread 03-02-2017, 16:18
waialua359's Avatar
AKA: Glenn
Well, I guess we shall see.
Unread 03-02-2017, 16:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Prepare to be disappointed. There's nothing special about the scenario Adam has outlined. Any system with a ratchet and pawl is going to behave exactly as he's explained. We had this happen multiple times in 2010 with our kicker and our hanger. It's a HUGE PITA when it happens. We had to use a giant flat head screwdriver and apply major force to the pawl to lever it to disengage. This is assuming you have a pawl that's actually accessible. If you're using a ratcheting wrench you're totally screwed.
Imagine trying to release a ratchet strap that has been ratcheted to significant tension. If you try to pull the release with your fingers without taking up some of the load with the handle, you will never get it undone. You have to release tension off the release bar in order to move it. This is exactly what will happen in the scenario outlined above.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-02-2017, 16:43
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
It is legal to remove the rope from the field without removing the robot from the rope. So couldn't you have two team members support the robot, while another team member releases the rope from the davit?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 03-02-2017, 16:46
Cory's Avatar
AKA: Cory McBride
No. Read the above. You have nowhere to support the robot to. You can't force it up because it's already pushed the touch pad to it's hard stop. The rope will be under hundreds of pounds of tension at that point. You cannot push the robot higher and therefore cannot relieve the tension.
2001-2004: Team 100
Unread 03-02-2017, 16:49
waialua359's Avatar
AKA: Glenn
This is a good point. I had assumed the same also as an alternative without carefully thinking about it.
I do recall your 2010 robot and didnt realize you had those issues also.
Unread 03-02-2017, 16:56
AdamHeard's Avatar
Lead Mentor
Read what I posted again, you're literally champing the field and that rope will be under significant tension. Good luck.
Unread 03-02-2017, 16:53
waialua359's Avatar
AKA: Glenn
Ours is accessible so looks like we will have to bring that large flat screwdriver head.
Or we can also do the other suggestion earlier with the current draw. Lots of time left to figure this out since our climber already made and it works.
Unread 03-02-2017, 16:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Interesting point. How is 973 dealing with this?
2017 Scoring Model
CAD Library | GitHub
Unread 03-02-2017, 16:24
AdamHeard's Avatar
Lead Mentor
If you have a ratchet and are planning on stalling against the top for the full second, it needs to be able to disengage under load OR you need some way to remove the load.
Unread 03-02-2017, 17:38
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
You could have it so the ratchet is easy to take off. Then you could unwind the rope.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
