Go to Post The worst that happens is we try our best and lose. And there's no shame in that. - pfreivald [more]
  #31   Spotlight this post!
Unread 03-02-2017, 16:05
AdamHeard's Avatar
Lead Mentor
Re: Climb Stopping Mechanism
Originally Posted by waialua359 View Post
Sorry, I'm slow. I dont quite follow?
When you hit the wall on top, your motor will go to stall (unless you're current limiting) and push very hard on the top.
Now imagine everything in the system is a spring, you're going to compress/stretch parts of the robot/field and load everything up.
Now there is a ratchet on there preventing you from backdriving (and you can't go forward any more as you're already loaded pretty firm into the field).
Now that's how you lock yourself onto the field.
  #32   Spotlight this post!
Unread 03-02-2017, 16:12
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
In 2010, we created a simple ratchet pawl system that worked for our climber. It should release if we at least carry the robot, releasing weight tension.
  #33   Spotlight this post!
Unread 03-02-2017, 16:15
AdamHeard's Avatar
Lead Mentor
You won't be able to release weight tension as you're literally clamping the field. Can't go the other way because of the ratchet as well.
  #34   Spotlight this post!
Unread 03-02-2017, 16:16
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Originally Posted by Daniel_LaFleur View Post
The light does not go on until a full second after the plate is pushed.
Hope your knot holds.
I'm expecting at least one case where a robot yanks its stopper knot out of the davit this year, especially with the crazy ratios that people are putting on their climbers.
  #35   Spotlight this post!
Unread 03-02-2017, 16:18
waialua359's Avatar
AKA: Glenn
Well, I guess we shall see.
  #36   Spotlight this post!
Unread 03-02-2017, 16:19
llung llung is offline
FRC #4048
llung is an unknown quantity at this point
The current measuring method works very well. We've used it in other instances in the past and plan on using it this year for the climber mechanism.
  #37   Spotlight this post!
Unread 03-02-2017, 16:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Interesting point. How is 973 dealing with this?
2017 Scoring Model
CAD Library | GitHub
  #38   Spotlight this post!
Unread 03-02-2017, 16:24
AdamHeard's Avatar
Lead Mentor
If you have a ratchet and are planning on stalling against the top for the full second, it needs to be able to disengage under load OR you need some way to remove the load.
  #39   Spotlight this post!
Unread 03-02-2017, 16:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Prepare to be disappointed. There's nothing special about the scenario Adam has outlined. Any system with a ratchet and pawl is going to behave exactly as he's explained. We had this happen multiple times in 2010 with our kicker and our hanger. It's a HUGE PITA when it happens. We had to use a giant flat head screwdriver and apply major force to the pawl to lever it to disengage. This is assuming you have a pawl that's actually accessible. If you're using a ratcheting wrench you're totally screwed.
Imagine trying to release a ratchet strap that has been ratcheted to significant tension. If you try to pull the release with your fingers without taking up some of the load with the handle, you will never get it undone. You have to release tension off the release bar in order to move it. This is exactly what will happen in the scenario outlined above.
2001-2004: Team 100
2006-Present: Team 254
  #40   Spotlight this post!
Unread 03-02-2017, 16:43
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
It is legal to remove the rope from the field without removing the robot from the rope. So couldn't you have two team members support the robot, while another team member releases the rope from the davit?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
  #41   Spotlight this post!
Unread 03-02-2017, 16:46
Cory's Avatar
AKA: Cory McBride
No. Read the above. You have nowhere to support the robot to. You can't force it up because it's already pushed the touch pad to it's hard stop. The rope will be under hundreds of pounds of tension at that point. You cannot push the robot higher and therefore cannot relieve the tension.
2001-2004: Team 100
  #42   Spotlight this post!
Unread 03-02-2017, 16:49
waialua359's Avatar
AKA: Glenn
This is a good point. I had assumed the same also as an alternative without carefully thinking about it.
I do recall your 2010 robot and didnt realize you had those issues also.
  #43   Spotlight this post!
Unread 03-02-2017, 16:53
waialua359's Avatar
AKA: Glenn
Ours is accessible so looks like we will have to bring that large flat screwdriver head.
Or we can also do the other suggestion earlier with the current draw. Lots of time left to figure this out since our climber already made and it works.
  #44   Spotlight this post!
Unread 03-02-2017, 16:56
AdamHeard's Avatar
Lead Mentor
Read what I posted again, you're literally champing the field and that rope will be under significant tension. Good luck.
  #45   Spotlight this post!
Unread 03-02-2017, 17:36
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Yes, but if you wait to stop your winch until AFTER the light comes on you will be putting the full power of your winch + the weight of your robot pulling on the rope for that second.
That's probably a decent amount of force (at least 300 lbs)
Just FYI, I agree with your point that teams need to have a solution to the problem.
However, in this circumstance, the force applied on the rope after hitting the stop at the top isn't "the full power of the winch + the weight of the robot pulling on the rope..."
Rather, it's the maximum of the two. (Which is likely to be the "at stall" torque from the winch.)
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
