Go to Post First is more than a competition it is a family. - amos229 [more]
  #46   Spotlight this post!
Unread 03-02-2017, 17:38
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Re: Climb Stopping Mechanism
You won't be able to release weight tension as you're literally clamping the field. Can't go the other way because of the ratchet as well.
You could have it so the ratchet is easy to take off. Then you could unwind the rope.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
  #47   Spotlight this post!
Unread 03-02-2017, 18:21
orangeandblack5 orangeandblack5 is online now
Hates LabView - Uses It Anyway
AKA: Ian Stewart
FRC #5498 (Wired Devils)
Rookie Year: 2015
orangeandblack5 will become famous soon enough
Wait... if you're using a ratchet wrench, could you not just reverse the direction the wrench is ratcheting?
  #48   Spotlight this post!
Unread 03-02-2017, 18:23
antman antman is offline
FRC #3238
Rookie Year: 2016
antman is an unknown quantity at this point
If you use a ratchet wrench you could clamp the non-ratchet end with a bicycle quick-release lever that can slide in a slot to drop below the wrench when the lever is opened.
  #49   Spotlight this post!
Unread 03-02-2017, 18:26
AdamHeard's Avatar
Lead Mentor
Please, go try this with 150 in-lb (or more) on the ratchet.
  #50   Spotlight this post!
Unread 03-02-2017, 18:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
No...that's the entire point of the discussion above. If you have a ratcheting wrench, attempt to tighten an already tight bolt. While applying a tightening force, try to flip the ratchet switch. It won't work. The pawl is under tension as well and you can't overcome it without significant force...far more than your fingers could apply.
2001-2004: Team 100
2006-Present: Team 254
  #51   Spotlight this post!
Unread 03-02-2017, 18:39
AKA: Ian Stewart
Rookie Year: 2015
Ah, thank you for explaining.
  #52   Spotlight this post!
Unread 03-02-2017, 20:34
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I've been mulling over whether or not it's legal cut the rope to release the robot. It's legal for your robot to damage team provided ropes (G15) as long as it doesn't leave debris on the field, and once the rope has been removed from the Davit it's no longer considered part of the field (R08 blue box).
As far as I can determine, it would not be legal because up to the point where the rope is cut and the robot is released, it's technically a person damaging part of the field (even though that part of the field is legally allowed to be damaged by a robot. Just not anything else). But it was an interesting read through the rules.
*Apex Robotics is not planning to release our robot in this fashion. But it did make me curious if it's a quick fix for teams who haven't planned around this*
  #53   Spotlight this post!
Unread 03-02-2017, 21:30
Oblarg Oblarg is offline
AKA: Eli Barnett
We're using a flex-head ratcheting wrench, i.e. just an ordinary ratcheting wrench except there's a pivot between the head and the handle. In order to lower the robot, we simply undo the velcro strap holding the wrench handle in a constrained position (i.e. between two bolts) and pivot it out of the way. The wrench rotates with the winch as it unspools.
"The breakfast of champions!"
  #54   Spotlight this post!
Unread 03-02-2017, 21:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Wow. I was at Lowe's shopping for ratchet wrenches this evening, and thought of essentially the same thing when I looked at the flex-head wrenges. I was thinking of using a non-flex head, non-reversible wrench, wedging it in a piece of aluminum channel (similar to your two bolts), and lifting it out parallel to the shaft. If you do this, be sure to mark the ratchet wrench as to WHICH SIDE FACES OUT, or you'll have a useless climber for a match or three.
Originally Posted by Nuttyman54 View Post
I've been mulling over whether or not it's legal cut the rope to release the robot. ...
I concur that with the rules as currently written, it would not be legal (Drive team damage vs robot damage). However, given the preamble to the answer to Q299, I suspect that a question on this topic would get a finding of legal even if it meant a rule change.
  #55   Spotlight this post!
Unread 03-02-2017, 21:50
AKA: Eli Barnett
The nice thing about the flex-head wrench is that we can constrain the head in-place to avoid that exact problem (though we probably ought to mark it anyway).
For those who are interested, this is the wrench in question:
https://www.amazon.com/TEKTON-WRN570...words=WRN57010
  #56   Spotlight this post!
Unread 03-02-2017, 22:02
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
From my experience, that is much easier said than done (with the non-flexible non-reversing). The wrench always wedged itself pretty tightly against the stop and we still needed to lift or rotate the robot slightly to get it out. There needs to be pretty much no load on the wrench to be able to slide it along the shaft to get it off (or far enough along the shaft to not be impeded). Granted, I've always done it using two bolts/screws as the stop, never channel.
I'll second the comment about marking which side of the wrench needs to be facing out, or which way the switch needs to be flipped if you're using a reversible wrench. Drill it into your pit crew's and drive team's heads. You can never double-check too many times.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #57   Spotlight this post!
AdamHeard's Avatar
Lead Mentor
Have you tried this after crashing into the top and holding full stall?
Depending on where it is in the gear reduction and the spool diameter it'll either be completely locked and tough to remove or trivial to remove by hand.
  #58   Spotlight this post!
Unread 03-02-2017, 22:07
AKA: Eli Barnett
The wrench is right on the spool shaft, and the spool diameter is 1.25''. It's got a nice long handle, and I seriously doubt it will be a problem though we have not tried "wedging" the robot like that yet (we will be current-limiting the climbing motor to prevent that, at any rate).
  #59   Spotlight this post!
Unread 03-02-2017, 22:48
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Might as well test "catastrophic failure mode" while you get a chance to do so in a more friendly environment.
Academic Student (Forever)
  #60   Spotlight this post!
Unread 03-02-2017, 23:31
Chris is me's Avatar
AKA: Pinecone
After reading all this, maybe it would just be better to climb early and let the robot backdrive as time expires... This seems tricky otherwise.
