Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 03-02-2017, 17:15
TeamImp219 TeamImp219 is offline
FRC #0219
TeamImp219 is an unknown quantity at this point
Flashing OM5p-ac router help
We are trying to flash an OM5P-AC router that will be put on our robot this year, and we are following the guide on FIRST's website but when we tried to configure the router we got the error "Bridge configuration failed: failed to change IP address, please ensure the bridge is connected to this computer and try again. We finished loading the firmware and then entered our team number, robot name, and have firewall and BW limit checked with the router connected to our computer and the power in. Does anyone know what is going wrong?
Unread 03-02-2017, 17:29
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
Re: Flashing OM5p-ac router help
Have you made sure that your computer is not connected to any wireless networks? That's been an issue for my team.
Unread 03-02-2017, 18:31
FRC #0219
The computer is not connected to any other Ethernet devices or wifi connections. It seems the computer may not be detecting the router for some reason.
Unread 03-02-2017, 19:03
Sky Captain's Avatar
Sky Captain Sky Captain is offline
Software Mentor and FIRST Volunteer
AKA: Will
FRC #0386 (Voltage)
Sky Captain is an unknown quantity at this point
Are you able to ping the router's default IP address? Are you running the config utility in administrator mode?
When in doubt, RTFM.
Unread 03-02-2017, 21:47
thecoopster20 thecoopster20 is offline
4th Year Programmer - Java
FRC #3602 (Robomos)
thecoopster20 is an unknown quantity at this point
One issue I found was with the power supply. I had a power cord that plugged into the wall, and that didn't provide enough power for whatever reason. Yet when I had the routers plugged into the supply from the robot, worked like a charm.
Unread 03-02-2017, 23:48
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Make sure that the ONLY network interface that is NOT disabled (not just having wifi turned off, but fully disabled in the Adapters settings window) is the wired ethernet port on the machine. Basically the machine's network adapters should be configured as if it was sitting in the Player Station on the field.
Make sure that the port on the radio that the ethernet cable is plugged into is the one AWAY from the power plug (the one that would NOT be connected to the roboRIO).
Nate
Unread 04-02-2017, 19:15
npetrie3 npetrie3 is offline
FRC #0135 (Penn Robotics)
Team Role: Electrical
npetrie3 is an unknown quantity at this point
The thing that ended up working for our team was to load firmware though a network switch. It helps with timeouts.
Sent from my iPhone using Tapatalk
Unread 04-02-2017, 19:34
MuskieProgramme MuskieProgramme is offline
FRC #6420
MuskieProgramme is an unknown quantity at this point
Since a large number of teams are having trouble with this, I decided to screenshot the screens I used to accomplish this (Windows 10).
http://imgur.com/a/Q9Gkr
Go to "Network and Sharing Center"
Click "Change adapter settings" -> This will open "Network Connections"
Right click and select "disable" for every connection listed OTHER THAN the one to the roboRIO.
