When you're around my motors redline.
Unread 03-02-2017, 15:38
mjc49's Avatar
mjc49 mjc49 is offline
Coach - Team 3042
AKA: Mike
FRC #3042 (Cobalt Catalyst)
mjc49 is an unknown quantity at this point
Gears Falling From the Lift
Does anyone feel that there will be gears that fall off when the pilot is lifting the gear into the airship? This may not be an issue as the game gets into the later weeks of competition, but I think that pilots will need to be careful not to jerk the lift when pulling up the gear.
(2013-Current) Coach-Team 3042 Cobalt Catalyst, MN North Star Regional Winners (2014 w/2177 & 4778, 2016 w/2175 & 3130)
2017 - LRI: MN North Star Regional
Unread 03-02-2017, 15:46
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: Gears Falling From the Lift
We started re-designing our gear manipulator this week, to get the gear farther on the lift, after finally receiving our spring. The before designs usually dropped the gear right on the edge.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 03-02-2017, 15:49
T8PineappleSam T8PineappleSam is offline
Jonathan
AKA: Jonathan Zwiebel
FRC #0008 (Paly Robotics)
Team Role: Driver
T8PineappleSam will become famous soon enoughT8PineappleSam will become famous soon enough
If you don't mind sharing, how far onto the spring did you find that the gear needed to be placed? We received our springs from MCM a few days ago although they appear quite a bit less 'springy' than those that others have shown.
Jonathan Zwiebel
Driver, Project Manager, Programmer [Team 8, Paly Robotics]
2016 Central Valley Regional Finalist and Wildcard, Silicon Valley Regional Quarterfinalist, Curie Division, CalGames Quarterfinalist and Entrepreneurship Award, Capital City Classic Quarterfinalist
2015 Central Valley Regional Entrepreneurship Award, Silicon Valley Regional Entrepreneurship Award, Capital City Classic Semifinalist and Judges' Award
2014 Central Valley Regional, Silicon Valley Regional, Chezy Champs
Unread 03-02-2017, 15:50
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Yes it will.
... and then the next robot will try and push it away while holding a gear, causing penalties.
___________________
- Tennyson, Ulysses
Unread 03-02-2017, 15:57
flemdogmillion's Avatar
flemdogmillion flemdogmillion is online now
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
They had better stiffen the spring. What's the point of a barb on the end if the gear falls off anyway?
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 03-02-2017, 16:00
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Why do they need to stiffen the spring.
Nothing has changed since kickoff, if teams do not test against the real field, then they get what they deserve.
___________________
- Tennyson, Ulysses
Unread 03-02-2017, 16:02
Jonathan
Team Role: Driver
The spring that we received from MMC could hold up the gear with it on only a few inches. We have seen images from other teams that show significantly more bending (mostly from this thread: https://www.chiefdelphi.com/forums/s...hreadid=153157) so we are unsure if ours matches the ones that will be used on the field. Later today I can take more specific measurements and pictures for how far onto the spring the gear must be placed.
Jonathan Zwiebel
Unread 03-02-2017, 16:04
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
While I agree that the field specs are out there, not all teams have access to an official field, and from the sounds of this season, the springs themselves were a nightmare to get the exact make and model listed.
It's kind of a harsh penalty to say "You're absolutely at fault for having limited resources."
Academic Student (Forever)
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
It's a game feature.
Unread 03-02-2017, 17:35
About 1/2 way. It will work with the gear at the very end, but it could fall off it nudged. Didn't take much to bend the spring.
www.valleyx2844.com
Unread 03-02-2017, 17:52
apm4242 apm4242 is offline
FRC #4242
apm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant future
We're considering delivering the gear at around 20-24" off the ground to reduce this. We figure the less time that the gear is on the lift, the better. The only downside I can think of is that pilots will need to be trained/prepped because they won't always be team members.
Anyone else considering this?
Unread 03-02-2017, 20:47
pmattin5459's Avatar
pmattin5459 pmattin5459 is online now
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
That sounds really hard and like a very tough job for your pilots to gauge such a rough distance. Not saying it won't work, just it's pretty tough and probably won't make too much difference in the end (that's like half a foot higher, right?). Better to just go with the consistent height imo.
Unread 03-02-2017, 20:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
we're planning on putting the gear firmly onto the spring...but I also expect us to be making some changes on practice day
Unread 03-02-2017, 21:07
Trevor1523's Avatar
Trevor1523 Trevor1523 is offline
Meme Queen
FRC #1523 (MARS / 6685 RPBHSR)
Trevor1523 is an unknown quantity at this point
I'd just like to point out that this is very similar to the Portculis/Sally Port fiasco that happened to us last year. We have the competition spring, and if it is placed just on the end of the peg, it will just slip off. If you put it about half way on with a little bit of a bounce then it will fall off.
Yes. There will be gears that fall off the lift this year, especially those gears that are placed on the very tip of the peg.
2015 Orlando Regional Finalists
FRC Team 1523 [2014-xxxx]
FRC Team 6685 [2017]
