Go to Post If robotics is bad for you, well then I guess I'm gonna die. At least I'll die happy. - karinka13 [more]
Unread 03-02-2017, 22:02
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Climb Stopping Mechanism
Originally Posted by GeeTwo View Post
Wow. I was at Lowe's shopping for ratchet wrenches this evening, and thought of essentially the same thing when I looked at the flex-head wrenges. I was thinking of using a non-flex head, non-reversible wrench, wedging it in a piece of aluminum channel (similar to your two bolts), and lifting it out parallel to the shaft. If you do this, be sure to mark the ratchet wrench as to WHICH SIDE FACES OUT, or you'll have a useless climber for a match or three.
From my experience, that is much easier said than done (with the non-flexible non-reversing). The wrench always wedged itself pretty tightly against the stop and we still needed to lift or rotate the robot slightly to get it out. There needs to be pretty much no load on the wrench to be able to slide it along the shaft to get it off (or far enough along the shaft to not be impeded). Granted, I've always done it using two bolts/screws as the stop, never channel.
I'll second the comment about marking which side of the wrench needs to be facing out, or which way the switch needs to be flipped if you're using a reversible wrench. Drill it into your pit crew's and drive team's heads. You can never double-check too many times.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
