Go to Post Being involved with FIRST is a privilege, not a right. - Katie Reynolds [more]
Unread 04-02-2017, 01:38
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Not able to connect with DS but able to deploy code
I am having a connection issue that only affects the Driver Station from connecting to the roboRIO. All my teammate's computer's do not have this problem. I am able to ping the roboRIO via command prompt and deploy LabVIEW code to the roboRIO-1094-FRC.local address over wifi. When I bring up the driver station the radio and roboRIO LEDs on the diagnostics page show green but I cannot get the communications LED (the one beside robot code) to turn green. I have tried wifi, Ethernet, and USB connections with no success. I have made sure my computer's IP address is automatic and all network connections except the one in use are disabled. I do not believe I had this issue last year.
Any suggestions? Thank you!
