Go to Post I'm going to get kicked out of the mentor club for this one... - Not2B [more]
Unread 04-02-2017, 08:45
mrada6 mrada6 is offline
FRC #5684
mrada6 is an unknown quantity at this point
OpenCV in java
Hye everyone I am a first year programmer in FIRST. we are trying to do some vision programing this year. I have the following thread that should perform an RBG max. and then find all the convex hulls. This part works. I then want to draw a rectangle around each of the convex hulls it finds. This is where the code bugs up saying "to many instances of camera"
new Thread(() -> {
            UsbCamera camera = CameraServer.getInstance().startAutomaticCapture();
            camera.setResolution(640, 480);
            camera.setExposureManual(-100);
            camera.setBrightness(15);
            CvSink cvSink = CameraServer.getInstance().getVideo();
            CvSource outputStream = CameraServer.getInstance().putVideo("Radaszkiewicz", IMG_WIDTH, IMG_HEIGHT);
            Mat source = new Mat();
            Mat output = new Mat();
            double[] red = {0,255};
    		double[] green = {40,255};
    		double[] blue = {0,255};
    		ArrayList<MatOfPoint> findContoursOutput = new ArrayList<MatOfPoint>();
    		boolean externalOnly=false;
    		Mat hierarchy = new Mat();
    		MatOfInt hull = new MatOfInt();
    		ArrayList<MatOfPoint> convexHullsOutput = new ArrayList<MatOfPoint>();
    		ArrayList<Point> points = new ArrayList<Point>();
            while(!Thread.interrupted()) {
                cvSink.grabFrame(source);
                Imgproc.cvtColor(source, output, Imgproc.COLOR_BGR2RGB);
        		Core.inRange(source, new Scalar(red[0], green[0], blue[0]),
        		new Scalar(red[1], green[1], blue[1]), output);
        		int mode;
        		if (externalOnly) {
        			mode = Imgproc.RETR_EXTERNAL;
        		else {
        			mode = Imgproc.RETR_LIST;
        		int method = Imgproc.CHAIN_APPROX_SIMPLE;
        		findContoursOutput.clear();
        		Imgproc.findContours(output, findContoursOutput, hierarchy, mode, method);
        			convexHullsOutput.clear();
        				for (int i = 0; i < findContoursOutput.size(); i++) {
        					final MatOfPoint contour = findContoursOutput.get(i);
        					final MatOfPoint mopHull = new MatOfPoint();
        					Imgproc.convexHull(contour, hull);
        					mopHull.create((int) hull.size().height, 1, CvType.CV_32SC2);
        					for (int j = 0; j < hull.size().height; j++) {
        						int index = (int) hull.get(j, 0)[0];
        						double[] point = new double[] {contour.get(index, 0)[0], contour.get(index, 0)[1]};
        						mopHull.put(j, 0, point);
        					convexHullsOutput.add(mopHull);
        				points.clear();
        				for(int i=0;i<convexHullsOutput.size();i++)
        					Point[] pointsTemp = convexHullsOutput.get(i).toArray();
        					//System.out.println("Ratio is: " + getRatio(pointsTemp));
        					for(int q=0;q<pointsTemp.length;q++)
        						points.add(pointsTemp[q]);
        					int maxXTemp = getMax(points,0);
            				int maxYTemp = getMax(points,1);
            				int minXTemp = getMin(points,0);
            				int minYTemp = getMin(points,1);
        					Imgproc.rectangle(source, new Point(minXTemp, minYTemp), new Point(maxXTemp, maxYTemp),
            						new Scalar(0, 0, 255), 5);
        				//error correcting.  find the center of each convex hull, then find the midpoint of the two centers.
        				int maxX = getMax(points,0);
        				int maxY = getMax(points,1);
        				int minX = getMin(points,0);
        				int minY = getMin(points,1);
        				int middleX = (maxX+minX)/2;
        				int middleY = (maxY+minY)/2;
        				pegX=middleX;
        				pegY=middleY;
        				SmartDashboard.putNumber("PegX",pegX);
        				SmartDashboard.putNumber("pegY", pegY);
        				int minRecX = middleX-5;
        				int maxRecX = middleX+5;
        				int minRecY = middleY-5;
        				int maxRecY = middleY+5;
        				sizeOfTarget=maxRecX-minRecX;
        				// Put a rectangle on the image
        				Imgproc.rectangle(source, new Point(minRecX, minRecY), new Point(maxRecX, maxRecY),
        						new Scalar(255, 0, 0), 5);
        				// Give the output stream a new image to display
        				outputStream.putFrame(source);
        }).start();
	 * This function is called periodically during test mode
	@Override
	public void testPeriodic() {
	public int getMax(ArrayList<Point> listOfPoints, int z)
		int max=Integer.MIN_VALUE;
		for(int i=0;i<listOfPoints.size();i++)
			int temp=0;
			if(z==0)
				temp=(int) listOfPoints.get(i).x;
			else
				temp=(int) listOfPoints.get(i).y;
			if(temp>max)
				max=temp;
		return max;
	public int getMin(ArrayList<Point> listOfPoints, int z)
		int min=Integer.MAX_VALUE;
			int temp=0;
			if(z==0)
			else
			if(temp<min)
				min=temp;
		return min;
