Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 04-02-2017, 11:31
Alex Chamberlin's Avatar
Alex Chamberlin Alex Chamberlin is offline
Gaff tape and love
AKA: Guy in the white hat
FRC #2521 (SERT)
Team Role: Tactician
Rookie Year: 2015
Alex Chamberlin is an unknown quantity at this point
How do you shoot so fast?
I'm seeing a lot of shooters shooting faster than ours, so the question is how did they get PID to return so fast ( >4 balls per second).
Our team is using an 8in pneumatic wheel direct drive to a cim, and we are getting about 1.5 balls per second when waiting for PID.
Unread 04-02-2017, 11:32
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: How do you shoot so fast?
Try adding mass to the rotational axis of the flywheel. It will take more time to reach your required speed, but once reached - it will decrease far less between balls fired.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 04-02-2017, 11:54
Brian Maher's Avatar
Brian Maher Brian Maher is offline
Questionable Decisionmakers
FRC #2791 (Shaker Robotics), FRC #1257 (Parallel Universe)
Brian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond repute
+1. More rotational momentum (by adding more mass to the flywheel) makes a world of difference. In addition, some teams will have multiple shooters on their robots.
2016-present, Mentor, FRC 2791 - Shaker Robotics
2016: Tech Valley SF (5236, 2791, 3624) and Quality, Finger Lakes SF (5254, 2791, 2383), Battlecry@WPI Winner (195, 2791, 501), Robot Rumble Winner (2791, 195, 6463)
2016-present, Mentor, FRC 1257 - Parallel Universe
2016: Mount Olive Winner (1257, 5624, 1676), Bridgewater-Raritan Finalist (1257, 25, 3340, 555) and GP, MAR CMP Winner (225, 341, 1257), Archimedes SF (4003, 4564, 5842, 1257), IRI Invite
2012-2015, Student, FRC 1257 - Parallel Universe
2015: Mount Olive QF (1257, 1811, 1923) and Safety Award, North Brunswick Finalist (11, 193, 1257) and Team Spirit and Safety Awards
2014: Clifton Winner (1626, 869, 1257), MAR CMP QF (1257, 293, 303)
2013: TCNJ Safety Award
2012: Mount Olive QF (204, 303, 1257)
Unread 04-02-2017, 12:45
Gaff tape and love
FRC #2521 (SERT)
Rookie Year: 2015
How would the amount of momentum taken by the ball or added by the motor change?
Unread 04-02-2017, 12:51
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
The gist I get from the programming team is that the Talon SRXs only feedback velocity information from the encoders on a 100ms timeframe, so making a control loop respond to multiple balls per second is extremely difficult with that route. Running the encoder into the digital I/O ports on the rio lets you make your own control system that is more responsive.
Unread 04-02-2017, 13:06
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
This is a good question, and most likely the answer is "It won't."
However, it will have a positive effect on your shooting characteristics. It will help the PID get back up to speed and stabilized, because it will increase the dampening in the system. Also if your shooter's RPM is off by some given amount of energy when a ball is fired, it will have a smaller impact on the shot.
On the other hand, the best advice I can give you is to increase the cycle rate of your PID and give the shooter more available power.
There are many ways to increase cycle rate, but only two ways to increase available power. Either gear the shooter to the power band of the motor you are using, or increase the amount of motors.
Hope that helps! (When in doubt, focus on gears and climbing)
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 04-02-2017, 13:14
Adnewhouse's Avatar
Adnewhouse Adnewhouse is offline
FRC #0639
Adnewhouse is an unknown quantity at this point
If you use the built in pidf control on the talons themselves, your motor loop runs really fast. This is probably a better route than running it on your roborio. The software manual for the talons also suggests that you can change this 100ms can bus encoder update rate to be faster (can be set to 20ms), but you shouldn't need to use this at all. My recommendation is to add more mass on to your flywheel, and experiment with a feed forward gain term if you are using talonSRXs.
Unread 04-02-2017, 20:27
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
PID sampling rate can affect your responsiveness as mentioned above, but physical setup is more likely your issue. More mass to the flywheel means it will have more inertia at speed. You need more energy to get to that inertia, so a longer ramp up, but the energy each ball takes from the shooter will be a lower percentage of the available inertia with the higher mass. I'd also look at your gearing, compression, and wheel contact time. A 1:1 ratio on an 8" wheel seems fast to me, since some Ri3D robots were shooting at the high goal with wheels half that size. I didn't look at their gearing, but direct drive CIM on a 4 inch wheel would give you double the available torque, which should decrease your time to spin back up to speed. More motors is also an option.
The rule in industry is, you don't fix mechanical problems with programming.
Unread 04-02-2017, 20:42
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
The motor stays the same. It is the addition of the flywheel that matters.
Let's say that the wheel is spinning at 600 rpms, and declines to 550 rpms after a shot. You have to wait for the wheel to spin back up to speed.
After adding the flywheel, the 600 rpms delines to 590 rpms after a shot. The motor then goes to 100% to speed back up to 600 rpms. You can then shoot as fast as the motor can deliver energy to the system.
Unread 04-02-2017, 21:45
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
How fast is your motor spinning when you're at during speed? If the motor is spinning near its free speed, there isn't much torque available to soon the motor back up to speed. You should have the gearing set up so when your wheel is at target speed, the motor is spinning at about 60% free speed. Then when your PID kicks the motor output up to 100%, it will dump the most power it can into the wheel to get it back up to speed.
Unread 05-02-2017, 12:16
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
You can actually drop it all the way down to a single millisecond.
That said, I suggest using the TalonSRX Speed Control Mode. You can set FPID values that should be able to get it up to speed very quickly and very consistently. While all mechanical systems are different, we had a two-wheeled shooter without any flywheel that was speeding up after shooting a ball in less than a tenth of a second.
Unread 05-02-2017, 12:50
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
The Talon closes the loop much faster than the roboRio WPI classes (by default). I think the Talon is nearly 10X faster. The 100ms comes up because the Talon counts pulses per 100ms instead of pulses per second - my guess is they do it to make the internal integer math easier. But, for sure, the 100ms thing has zero to do with how fast the Talon's close the loop.
HTH
Unread 05-02-2017, 13:04
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Another thing to consider is reducing the amount of energy lost per ball. If your system compresses the ball a lot during a launch, more energy will be lost - which needs to be replaced.
Fuel weighs about 0.0707 kg, launched at 6 m/s will have an energy of 12.73 J
(https://www.wolframalpha.com/input/?...elling+6+m%2Fs)
Shooting five of these per second is only 64W - ignoring other loses. Those other loses could be hampering your shooting rate.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 05-02-2017, 13:46
gbear605's Avatar
Scarebear
HTH
According to both the documentation and CTRE, the Talon control loop runs every millisecond. It is very possible to use the Talon for closed-loop code. I think you can apply the Cheesy Poof rule here: 254 uses closed loop velocity control on the Talons, so you can too.
Unread 05-02-2017, 16:16
DonRotolo's Avatar
Back to humble
FRC #0832
Direct drive may be sub-optimal, depending on your target wheel speed. Try to have the CIM running at about 50% speed when your wheel is at full speed.
This allows the motor to have sufficient "headroom" to pour in the power when needed.
We are running a 775 at 5:1 reduction, wheel speed is about 1000 RPM* on an 8" solid wheel. Our shot doesn't go much higher than the fuel inlet (by design).
*(I may be mistaken on this value, but I don't think it is higher than 2000 RPM)
